First off I want to thank Brian for continuing to update his UI2/UI3 tool. I encourage everyone to donate to his cause through paypal for making BI a better tool to use with his help for the add on. Unfortunately, I use a Samsung smart TV for my main large monitor to view real time video, and not interested in reviewing clips or panning the PTZ in that application. The Samsung smarthub TV does not support the new APIs that are used in the UI3 tool, but work great with UI2. I cannot get a full screen view on the TV, with the icon in lower right corner, but very happy with UI2 after setting correct setting in BI UI. Although, I use it on travel to review clips on a win10 laptop. I do not expect Brian to support all these different clients, because it becomes a nightmare for support. UI3 looks like it works very well on a win10 Chrome browser use, but the size of the clip review thumbnails makes it very difficult to see for a review. I have many different clients set up for UI2 and UI3. Brian, Thanks for ALL your support and help with your tool! I am sure everyone feels the same. People like you make this Forum so great. Keep up the great work.
Man this is awesome, thanks so much!
Question... Can we launch into full screen mode automatically by passing a parameter in the URL string?
The enter the same address i used on the computer, http://xxxxxx/ui3beta/ui3.htm
Here is a screenshot from my S7.
I used to be able to use a string like this in the URL
Ui2.htm?full=1&cam=camname&full screen=1
Currently this loads the cam expanded however it doesn't minimize the UI and enable full screen
mac, safari, b10.
i have noticed that when i zoom in on live view past 2.5-3x, the screen will sometimes go black. zooming back out sometimes makes it go back to normal. sometimes, i get an orange message box 'your CPU is not fast enough...'.
So today, just for kicks, I tried pulling up UI3 in a browser and what do you know it loads! Looks pretty sweet. Works for a few seconds and then I get an error, something about NTP. I assume this is not meant to be running on a TV browser. Any chance this is an easy fix?
I don't know what is going on there. The error message is totally bogus and makes me suspect the TV's browser is injecting its own broken script, and then UI3's catch-all error handler reports the error to you.
I noticed that you are using an LG smart TV. I have a ~3yo LG OLED TV but the browser (Web OS2) does not allow a very long screen saver disable timeout. Meaning a screen saver comes on after short period of time. I also have a Samsung smart TV that allows a 10 hr disable for screen saver, which I use for the UI2 tool. Does your LG TV allow a long screen saver disable time? If so is it Web OS3?
Any idea how to change the web interface timeout?
