fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
try disabling the firewall and test.
I currently have no firewall's running. all turned off.try disabling the firewall and test.
What version of BI are you running? I tested silk on firestick 4k with 5.2.1.4 as well as the latest 5.2.4.6 and its working fine.I currently have no firewall's running. all turned off.
i am using 4 with the last update before it went to 5 which is when my subscription ran out... i didn't think this would be an issue since there hasnt been a ui3 update since it stopped working.What version of BI are you running? I tested silk on firestick 4k with 5.2.1.4 as well as the latest 5.2.4.6 and its working fine.
There is only one way to find out...the update is worth 30 bux.i am using 4 with the last update before it went to 5 which is when my subscription ran out... i didn't think this would be an issue since there hasnt been a ui3 update since it stopped working.
i am only seeing a price of $69.95There is only one way to find out...the update is worth 30 bux.
blueirissoftware.com
I dont think is amazon, as I tested it with my firestick. The upgrade is worthwhile regardless so it cant hurt to try.It is highly unlikely that updating to BI5 would help with that. It sounds like Amazon's problem or a local configuration problem that we don't know about.
I just now reset the firestick to factor defaults and started fresh. UI3 now works again in Amazon Silk Browser. Somewhere somehow i must of installed something that made it go buggy.Hmm.
Well there is absolutely no reason I can think of for the Silk browser to behave any differently with BI 5 than it does with BI 4. And if it works for you then that points at it being a local configuration problem we don't know about.
Just tried it here, and no issue. Timed to the second.Anyone notice that in UI3 when you are reviewing clips then pause the playback and click the "take picture" icon in the upper right it saves a pic that is different than the paused image you are viewing? Looks like the timing is off.
Since installing BI 5.2.5.7 the new VBR settings in Ui3, cause lots of compression artifacts. The CBR settings work fine. This is in Chrome on two different 'puters. Thanks
The timing is exactly right for me. In UI3 settings, try changing the H.264 player to "JavaScript" and see if that fixes it. If so that would suggest the issue is with frame timing with the HTML5 player, which would not surprise me very much.
