I think so...how do you mean where first and last are options?
Edit: I get it. Yes, definitely!
Try the latest version: UI3-87
I thought of that initially when I deleted 35 and 11 remained, but 35-11 = 24.
Then when I deleted 26 and 1 remained.. 26-1=25
I am so glad that I discovered UI3! It works very well for me and is a great convenience. Quick question: When I started using this a while back I was able to change the "TIMEOUT" setting to "0", which of course allowed me to monitor my cameras without a timeout. That setting remained at "0" and I never had to change it again. Now, after building a new computer and running UI3, I find that my UI timeout setting will not save. If I set the time out to "0" and then close the page I must reset the timeout each time I log back in to UI3. I know it sounds like a minor concern but is there anyway around this, since I do it several times per day?
Ken told me this should be fixed for the next BI release!
Check your browser settings, extensions, etc to make sure cookies are enabled. Technically the feature used by UI3 to store settings is called "Local Storage" but usually that is controlled by the cookies setting because they are very similar in their purpose.
If your browser is overly aggressive with its privacy settings, that too could cause local storage to be wiped constantly, making you lose your setting.
If you can't fix this, there is a way you can change your default UI3 settings, but it is better if you can fix the problem preventing your settings from being saved.
Well that was easy enough! Thank you. I did have cookies disabled, as I typically do. I appreciate your help and all of your efforts with this. This is a great addition to the wonderful world of Blue Iris.
