This feature is already built into BIT in the "Options" tab, then the "Backup" button on the bottom right.Mike, great tools, and thank you for doing this.
Would you consider adding a BI reg backup function for the entire BI reg key: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Perspective Software
I regularly test and change various settings for my 12 cams to try out new/better triggers or features and it would be nice to revert to a backup of this entire tree.
The "backup" feature in BI has failed me a few times already because it backup (overlays prev backup) each time you launch BI so you really have to be mindful, plus you always have to enter the reg key if you do restore from that backup.
Anyway, I'd appreciate it if you consider this of value and add this functionality at some point.
Mark
