TL1096r
- Jan 28, 2017
- 1,211
- 472
Thank you!! really appreciated. I'm currently connecting 3 cams but will be added 2 or so more at some point (Once i have enough money and fix my infrastructure with BI etc.)
by Push notifications i mean event alerts on mobile (emails are too slow for me and the event is gone by the time they are received - i like to know when someone has entered my property at that moment). I currently have the gDmss plus and vpn setup - even if i'm not connected to the vpn i will get push notifications for events popup, i can then connect to VPN and view the video or pictures of the event.
I will look out for this pcs, thank you so much for the help again!
gDmss is going through a server in China first isn't it? BI is going from computer to you on network so it should be quicker. I wonder if there is any lag time between alerts. I don't know from experience with both but thought I throw the question out there.
This is a nicely priced POE switch if you only have 3 cams now and adding 2 later:
https://www.amazon.com/GS1008HP-Gigabit-Ethernet-Fanless-Desktop/dp/B07LH8R3FH
The hardest part sometimes is just getting it all together. Once I had my computer, POE switch and learned how to setup dual NIC I was up and running in a day. Look how to optimize BI:
Optimizing Blue Iris's CPU Usage | IP Cam Talk
For your setup you might be able to get an older generation intel:
Choosing Hardware for Blue Iris | IP Cam Talk
