Blue Iris Constantly Crashing
It has to have a DB folder somewhere.
It is one of the reasons why many here find a stable version and then doesn't update until something is added that they want or need.
Strange but I put a copy of the db folder on the desktop and not in the c: blue iris directory as I took it out . The system never created a new one ...
I think this is an on going issue. Some setting will make it worse, and most of time, BI wiill crash and restart and most user dont even notice it
I have all those crashes since first day of BI, and I searched the forum many times for a solution, and there is no solution.
Many people been complaining about it, if you search "0xc0000409 blueiris" or "0xc0000005 blueiris" on google
Many will just suggest to clean install, windows, BI, start everything from fresh. I have try all of those, non of them help to completely solve BI crashing, some will make it better (So, I'll live with it)
For those who claim BI is running perfectly fine in the system, just take a look in the folder "C:\Users\[BI_USERNAME]\AppData\Local\CrashDumps", I am pretty sure (like 99% confident, if you run your BI over a year or so), you will find a few crash dump file like the screenshot below. And then find the crash report in windows event log, it is most likely one of the 0xc0000409 and/or 0xc0000005 errors
My machine:
Friend's machine:
Unfortunately, at this point I am very pessimistic to find a solution for this issue as completely fixing those kind of crashes,
Since there is no clear cause of the crash. As from my dump files, it crashed a lot in March and early April, and then ran fine until May 25th, and I didnt change anything during those days. Same thing from December last year
I am also very pessimistic if dev ever care to fix those crashes, as many been complain a lot already, and then people stop respond to the post, and the post eventually die without a clear solution nor attention from BI dev
Oh well, live with it or find another software... I'll live with it for now
My machine:
Friend's machine:
Mornin
I have ended up wiping it out ( Which I hate to do ) and rebuilding ) It seemed to be stable for a while but then last week I got a records too large in red error msg . I will DEF take a look at this - Thx !
My machine:
Friend's machine:
I've been using BI for over 6 years. I only found one dmp file for BI and it's recent. As I recall there was some sort of significant power issue that day. I didn't read all your posts but I'm pretty confident that someone probably already mentioned the video driver you have on your system. This issue had something to do with a memory leak due to having an incompatible video driver. I recall having to locate an older video driver for my system and installing it to fix the issue. It was six years ago so I don't have the details on the specifics but if you do a search for "memory leak" you'll find plenty about it.
0xc0000005, Access is denied or Access Violation error​
Is the service account used for BI a member of the Administrators group?
you have the cleanest dump file folder i have ever seen!
Does video driver matter if Hardware accelerated decode is system wide off? Also blueiris software forum is pretty dead with a bunch 404 results
And yes BI is running with system admin right, or else it won't start, I tried that years ago when i was setting it up
The Blueiris forum is NOT dead, they just changed the URL, and don't want it linked to; here is what they posted about it
You will now find the user forum at /bbs on this website (sorry, a clickable link must be avoided). We are battling spam bots, web crawlers and the like that cause thousands of “guest users online” ultimately crippling our web server’s ability to do its job. Anti-spam and anti-bot measures have proven to be inadequate to battle this nuisance. The forum link will be updated within the software Help page going forward to reflect this and any further changes to the forum URL. Apologies for the inconvenience, but hopefully this will make the forum (and this website) more responsive for everyone using it.
Yeah, not surprised. I've seen unwelcome bugs on DIY boards here and there over the years.
Early on, in the computing Era, no self respecting Nerd, wanted to be "held hostage" by manufacturer offerings.
Building your own box was the way to get the features you wanted.
As time ticked on though being a non-gamer, I found the stability Windows inside boxes by HP and Dell, Lenovo/IBM for Corporate campus computing be satisfying to me. Esp when supporting a small business. the modular Optiplex was my go to PC because parts were readily available online.
Not all of my Dells ran BI rock solid, the 7020 with a 3rd gen Intel chip, ( pre substream/ Pre BI recommending turning OFF Hardware acceleration) was flaky. Never had any issues with the PC as a Home PC, but it wasn't BI ready IMHO.
got wind of the HP elitedesk thru a post by Fenderman, and that has been rock solid.
Then my BI for Home use was a Dell Optiplex 9020/4590 i5 chip. its been awesome for home use.
Then I decided to Run BI on a daily driver with enough power for daily computing as well. Thats when I decided to try the Dell Precision 3630 tower, which has been an awesome PC.
Hardware must be glitchy somewhere. what kinda box you runnin?
this box has been 99% uptime for a couple years.
I ran my BI in the following hardwares
Office:
Includes NVIDIA RTX3050 GPU, latest studio driver
Hardware acceleration off, GPU is mostly handing CodeProject.AI stuff
Home:
Includes NVIDIA RTX3070Ti GPU, latest studio driver
Hardware acceleration also off, GPU is mostly handing CodeProject.AI stuff as well
If i could get my hands on other hardware, I'll try it, but i currently office and home, we dont have the budget nor that we wanna upgrade machines we currently have
Office spent a lot of $ on that hardware
