I just upgraded my analog camera DVR from a Swann DVR8-4900 to a Hanwai ARD‑810. It seemed to work well until I noticed that Blue Iris is throwing red “Check FPS and Key Rates.” errors and my server's CPU is ranging between 90-100% - it used to run at 50-60% with the Swann DVR. An AI query revealed that my Hanwai RTSP output uses dynamic frame timing and adaptive GOP. It outputs a fixed, non‑standard, variable‑frame‑rate RTSP stream that BI6 cannot decode cleanly, leaving Blue Iris stuck in a CPU‑heavy error‑correction mode. Does anyone have a workaround for this issue? Is there anything in BI development that would improve BI handling of this type of RSTP stream?
