looney2ns
I vote for the EXE as well.
Thank you Mike for your continued support on this!
@aesterling I just posted Version 3.0 and this version can display the plate characters on screen using BI's overlays just like the Plate Recognizer integration@MikeLud1 this is excellent work, as always! Thanks for building and sharing!
A bit of a side question if you don't mind, I'm wondering if I would be able to display the plate characters on screen using BI's overlays, like I'm doing currently with the Plate Recognizer integration?
Example:
View attachment 114710 View attachment 114712
Try stopping the service (see Start Menu DeepStackALPR) after stopping the service try copying the ini file and repasting back in the folder as the same file name. After making changes restart the service (see Start Menu DeepStackALPR). Let me know if that works.it wont let the DS_ALPR_config.ini be modified and saved.
It looks like the software I am using to create the install exe (InstallForge) is saving all the file to the DeepStackALPR folders that requires admin rights to edit them. So if you need to edit the ini file open notepad first with admin rights then open the ini file. I will try to fix this tomorrow.Thank you that worked. started the service back up now just have to wait for a car to come by
In V3.1 I will add the option to change the models used by the APIIs it possible to use other models with this addon?
Most of these settings will not help with the wide plates you have in Denmark. In Version 3.1 I am going to add a setting to help with wide platesis it possible to use your models and tweak the “overlapping_threshold, min_conf_thres, min_len_thres, & plate_len_threshold” ? and which one to change(what do they do)?
YesWhat are the second numbers in the detection ex. [515]? Is it detection time?
isn't it very slow?
I see other peoples time around 100ms.
There are so many factors coming into play - is it GPU or CPU version, how many models running on system, how many cameras trigger at the same time, etc. Anything less than 1 second is probably ok for most.
If you want to learn how to create a custom model see the link belowIs it possible to train my own DS model? I get a lot of cancelled alerts even with very clear plates in FOV.(at night)
Currently i am using licence-plate model but i was told that is was trained onlywith daytime images.
docs.deepstack.cc
