Wait for version 2.0, I should have it posted by end of day FridayThis is freaking cool! I haven't tried it yet (I may have some time this weekend to play around with it), but it looks perfect. I was having many issue swith the ALPR built into BI but I'm looking forward to trying this.
Last night I sent Ken (Blue Iris Support) some changes that will help the DeepStack ALPR integration.
Can you please make some changes the help the integration, they are listed below
- When sending Blue Iris a JSON trigger can you have Blue Iris respond with the file name for the alert and add the memo to the log, currently it only shows “external”
- If you turn off Burn label mark-up onto alert images the alert image that is saved is the motion triggered image not the image DeepStack confirmed. Can you please change to the confirmed image
Wait for version 2.0 to fix the issues you are having, I should have it posted by end of day FridayI do have the flagged image, but no other kind of files in the folder.
BR
I plan to. Quick question - we need to input the username/pw of BI in the .ini file. What rights does this userid need (admin, read only, only able to view the camera used for LPR, etc)?Wait for version 2.0, I should have it posted by end of day Friday
I am not sure, I will look into it.I plan to. Quick question - we need to input the username/pw of BI in the .ini file. What rights does this userid need (admin, read only, only able to view the camera used for LPR, etc)?
Thanks again! looking forward to trying this!
I am planning on doing that may not be in version 2.0@MikeLud1 this is excellent work, as always! Thanks for building and sharing!
A bit of a side question if you don't mind, I'm wondering if I would be able to display the plate characters on screen using BI's overlays, like I'm doing currently with the Plate Recognizer integration?
Example:
View attachment 114710 View attachment 114712
Don't worry about looking into it. When I try, I will use an admin account and then work my way down from there after it's working. You're doing enough without worrying about little things like thisI am not sure, I will look into it.
