Did you create the below folder and placed the attached APLR.JPG in it? I also attached my config file if that helps
Yup.
@pbc Do you have admin rights to the Deepstack ALPR folder? There is a problem with install that puts the folder as read only.
Below are the settings that need to be changedOkay, still trying. Some of the things I've done:
- I went into the BI and DeepstackALPR directories and ensured they were not read only and all users had rights
- Reinstalled DeepstackALPR.exe (when I did this it gave me an error that NSSM could not run, maybe because it had already run?)
- Checked that the "file path.txt" file was being overwritten, it seems to be
- Checked that the service is running (this might be an issue, as quite often I will go check it and it says it is paused and I have to resume it?)
- The other possibly weird thing is that when I stopped the service, then ran the CMD commands (in Admin mode) it just hung at the below? Maybe because it was waiting for an image?
Here is all my associated setup and files:
- BI server address and port: 192.168.1.60:911
- Deepstack: 127.0.0.1:81
- LPR Camera (short name is LPR in BI): 192.168.1.71
Config file (note admin user has Admin rights in BI):
BI AI Tab:
LPR Camera settings:
View attachment 140272View attachment 140273View attachment 140274
View attachment 140275View attachment 140277
Note: I have no actions in the Alert tab for the LPR camera, should I?
ALPR Crop Camera settings:
View attachment 140278View attachment 140279View attachment 140280
View attachment 140281View attachment 140282View attachment 140283
Directories:
View attachment 140285View attachment 140286
@MikeLud1 when you get a chance let me know if something in the above seems off? Have tried to include relevant shots of everything!
- LPR Camera check the Plate Recognize setting
- ALPR Crop Camera should have the IP set to 127.0.0.1:81
- ALPR Crop Camera confirm that Configure Run Action is a Immediate Action
I missed that you changed the default port for Blue Iris from 81 to 911 make the below changeOkay, getting somewhere, looks like there is a 404 error showing up here which must be the culprit?
- ALPR Crop Camera should have the IP set to 127.0.0.1:911
CorrectAlso just to confirm, in the crop camera, AI is not supposed to be turned on?
Is Blue Iris, DeepStack, and DeepStackALPR all installed on one system?Also just to confirm, in the crop camera, AI is not supposed to be turned on?
