Vettester
- Feb 5, 2017
- 1,065
- 1,064
I'm still working on it. It's snowing here and my LPR camera is going nuts with canceled alerts.Is the rest of DeepStackALPR working for you.
Great, is all parts working, see below. Does your camera have more zoom, if so zoom in it will help with the character reading. For the OCR to work you need about 100 pixels across the plate.It is working, but it is running really slow. I'm running the CPU version of deepstacks and it seems to be a lot of plates.
From what I can tell it looks like the API is not communicating back to Blue Iris.And here's the actual BlueIris logfile from today
Yep, everything seems to be working but I need to zoom in a little bit more. To do this I'll have to adjust the mounting a bit so it will have to wait for a dryer warmer day,Great, is all parts working, see below. Does your camera have more zoom, if so zoom in it will help with the character reading. For the OCR to work you need about 100 pixels across the plate.
Great, do you have any suggestions to make the instructions easier to use and understand.Yep, everything seems to be working but I need to zoom in a little bit more. To do this I'll have to adjust the mounting a bit so it will have to wait for a dryer warmer day,
The only thing that wasn't clear to me was the IP address for the ALPR camera. You could add something that clearly define this.Great, do you have any suggestions to make the instructions easier to use and understand.
I think if you rotate the camera to the left and zoom in you will still get both lanesYep, everything seems to be working but I need to zoom in a little bit more. To do this I'll have to adjust the mounting a bit so it will have to wait for a dryer warmer day,
That will work.How does this look
Sure, no problem. The camera is mounted in a tree inside a birdhouse so it might take me a few days to make some adjustments.Once you get some plates would you be willing to share the below files so I can retrain the model.
Hey MikeFrom what I can tell it looks like the API is not communicating back to Blue Iris.
Try manual running the API in a Command Prompt using the below steps. Post a screenshot of the Command Prompt so I can see if there are any errors. Below is a normal Command Prompt
First stop DeepStackALPR Service using Task Manager
Next Open up Command Prompt and execute the below commands
- cd C:\Program Files (x86)\DeepStackALPR
- deepstackalpr.exe
The error I am see has to do with rights to the car.jpg file, try deleting the file. DeepStackALPR will recreate the file when there is a new plate identified.OK - I lied (about it working and about me taking a break. I just hate to lose to a computer LOL). I don't know why it worked "some" last night. I glanced and saw a few jpgs in the Alerts\ALPR folder when nothing had been there before. But then I realized last night was work night at the club so there was 20-30 cars/truck pulling in and out between 4:00pm and 9:00pm and there were only 3 jpgs in the folder. And now this morning there's been a few cars in and out an nothing. Running the deepstackalpr.exe manually I see there is a permissions error.
Attached is the log file from the Alerts/ALPR/20220216/ folder. It appeared to write a couple of files to that folder today instead of creating a new 20220217 folder.
Last question - Any reason you can think of that Deepstack would pick up the first 2 licenses plates and not the 3rd?
The program I use to create the install package is adding read only rights to the folder where the files are, I might need to do away with the install package and just have a zip file
Still getting the permission denied errorI deleted and rebooted the machine. Thursday is usually a little slow down there during the day so it may take a while for a car to drive thru. After one does, I'll check for the file. If it's there, I'll stop the service and start the API manually again and wait for another car
I will try to make a new install that I hope will address the rights issue.Still getting the permission denied error
If I'm the only one with this issue, don't make any changes on my account. I really appreciate it thoI will try to make a new install that I hope will address the rights issue.
