2024-09-28 15:05:39: Preparing to install module 'ALPR'
2024-09-28 15:05:39: Downloading module 'ALPR'
2024-09-28 15:05:40: Installing module 'ALPR'
2024-09-28 15:05:40: Installer script at 'C:\Program Files\CodeProject\AI\setup.bat'
2024-09-28 15:05:40: ALPR: [0;33m[49m             Installing CodeProject.AI Analysis Module                [0m
2024-09-28 15:05:40: ALPR: [0;32m[49m======================================================================[0m
2024-09-28 15:05:40: ALPR: [0;32m[49m                   CodeProject.AI Installer                           [0m
2024-09-28 15:05:40: ALPR: [0;37m[49m289.2Gb of 476Gb available on no (Windows 10 x86_64 - windows)[0m
2024-09-28 15:05:40: ALPR: [0;97m[104mGeneral CodeProject.AI setup                                          [0m
2024-09-28 15:05:41: ALPR: [0;39m[49mCreating Directories...[0m[0;92m[49mdone[0m
2024-09-28 15:05:41: ALPR: [0;97m[42mGPU support                                                           [0m
2024-09-28 15:05:41: ALPR: [0;39m[49mCUDA Present...[0m[0;32m[49mYes (CUDA 11.8, cuDNN 8.5)[0m
2024-09-28 15:05:41: ALPR: [0;39m[49mROCm Present...[0m[0;33m[49mNo[0m
2024-09-28 15:05:41: ALPR: [0;39m[49mChecking for .NET 8.0...[0m[0;39m[49mChecking runtimes...[0m[0;32m[49mAll good. .NET is 8.0.6[0m
2024-09-28 15:05:43: ALPR: [0;37m[49mReading ALPR settings[0m[0;37m[49m.[0m[0;37m[49m.[0m[0;37m[49m.[0m[0;37m[49m.[0m[0;37m[49m.[0m[0;37m[49m.[0m[0;37m[49m.[0m[0;32m[49mdone[0m
2024-09-28 15:05:43: ALPR: [0;97m[104mInstalling module License Plate Reader 3.3.0                          [0m
2024-09-28 15:05:43: ALPR: [0;37m[49mInternal module install[0m
2024-09-28 15:05:43: ALPR: [0;39m[49mInstalling Python 3.9[0m
2024-09-28 15:05:43: ALPR: [0;32m[49mPython 3.9 is already installed[0m
2024-09-28 15:05:51: ALPR: [0;39m[49mCreating Virtual Environment (Local)...[0m[0;32m[49mdone[0m
2024-09-28 15:05:51: ALPR: [0;39m[49mConfirming we have Python 3.9 in our virtual environment...[0m[0;32m[49mpresent[0m
2024-09-28 15:05:51: ALPR: [0;30m[49mDownloading ALPR models...[0m[0;95m[49malready exists...[0m[0;95m[49mExpanding...[0m[0;32m[49mdone.[0m
2024-09-28 15:05:51: ALPR: [0;39m[49mCopying contents of ocr-en-pp_ocrv4-paddle.zip to paddleocr...[0m[0;32m[49mdone[0m
2024-09-28 15:05:51: ALPR: [0;39m[49mInstalling Python packages for License Plate Reader[0m
2024-09-28 15:05:52: ALPR: [0;[49mInstalling GPU-enabled libraries: [0m[0;32m[49mIf available[0m
2024-09-28 15:05:53: ALPR: [0;39m[49mEnsuring Python package manager (pip) is installed...[0m[0;32m[49mdone[0m
2024-09-28 15:06:06: ALPR: [0;39m[49mEnsuring Python package manager (pip) is up to date...[0m[0;32m[49mdone[0m
2024-09-28 15:06:06: ALPR: [0;95m[49mPython packages specified by requirements.windows.cuda11_8.txt[0m
2024-09-28 15:06:15: ALPR: [0;39m[49m  - Installing NumPy, a package for scientific computing...[0m[0;32m[49m(✅ checked) [0m[0;32m[49mdone[0m
2024-09-28 15:06:17: ALPR: [0;39m[49m  - Installing PaddlePaddle, Parallel Distributed Deep Learning...[0m[0;91m[49m(⌠failed check) [0m[0;32m[49mdone[0m
2024-09-28 15:08:09: ALPR: [0;39m[49m  - Installing PaddleOCR, the OCR toolkit based on PaddlePaddle...[0m[0;32m[49m(✅ checked) [0m[0;32m[49mdone[0m
2024-09-28 15:08:11: ALPR: [0;39m[49m  - Installing imutils, the image utilities library...[0m[0;32m[49m(✅ checked) [0m[0;32m[49mdone[0m
2024-09-28 15:08:12: ALPR: [0;39m[49m  - Installing OpenCV, the Computer Vision library for Python...[0m[0;32m[49mAlready installed[0m
2024-09-28 15:08:24: ALPR: [0;39m[49m  - Installing the CodeProject.AI SDK...[0m[0;32m[49m(✅ checked) [0m[0;32m[49mdone[0m
2024-09-28 15:08:24: ALPR: [0;39m[49mScanning modulesettings for downloadable models...[0m[0;37m[49mNo models specified[0m
2024-09-28 15:08:24: ALPR: [0;39m[49mExecuting post-install script for License Plate Reader[0m
2024-09-28 15:08:24: ALPR: [0;39m[49mApplying PaddleOCR patch[0m
2024-09-28 15:08:24: ALPR:         1 file(s) copied.
2024-09-28 15:08:26: ALPR: Traceback (most recent call last):
2024-09-28 15:08:26: ALPR:   File "C:\Program Files\CodeProject\AI\modules\ALPR\ALPR_adapter.py", line 11, in <module>
2024-09-28 15:08:26: ALPR:     from ALPR import init_detect_platenumber, detect_platenumber
2024-09-28 15:08:26: ALPR:   File "C:\Program Files\CodeProject\AI\modules\ALPR\ALPR.py", line 17, in <module>
2024-09-28 15:08:26: ALPR:     from paddleocr import PaddleOCR
2024-09-28 15:08:26: ALPR:   File "C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\lib\site-packages\paddleocr\__init__.py", line 14, in <module>
2024-09-28 15:08:26: ALPR:     from .paddleocr import *
2024-09-28 15:08:26: ALPR:   File "C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\lib\site-packages\paddleocr\paddleocr.py", line 21, in <module>
2024-09-28 15:08:26: ALPR:     import paddle
2024-09-28 15:08:26: ALPR: ModuleNotFoundError: No module named 'paddle'
2024-09-28 15:08:26: ALPR: [0;39m[49mSelf test: [0m[0;91m[49mSelf-test failed[0m
2024-09-28 15:08:26: ALPR: [0;95m[49mModule setup time 00:02:44.21[0m
2024-09-28 15:08:26: ALPR: [0;97m[42mSetup complete                                                        [0m
2024-09-28 15:08:26: ALPR: [0;95m[49mTotal setup time 00:02:45.73[0m
2024-09-28 15:08:26: ALPR: [0;33m[49mSETUP FAILED:[0m
2024-09-28 15:08:26: ALPR:  - [ALPR] Self test failed
2024-09-28 15:08:26: Module ALPR installed successfully.
2024-09-28 15:08:26: Running module using: C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Scripts\python
2024-09-28 15:08:26: Attempting to start ALPR with C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Scripts\python "C:\Program Files\CodeProject\AI\modules\ALPR\ALPR_adapter.py"
2024-09-28 15:08:26: Starting C:\Program Files...ws\python39\venv\Scripts\python "C:\Program Files...\modules\ALPR\ALPR_adapter.py"
2024-09-28 15:08:26: ** Module 'License Plate Reader' 3.3.0 (ID: ALPR)
2024-09-28 15:08:26: ** Valid:            True
2024-09-28 15:08:26: ** Module Path:      <root>\modules\ALPR
2024-09-28 15:08:26: ** Module Location:  Internal
2024-09-28 15:08:26: ** AutoStart:        True
2024-09-28 15:08:26: ** Queue:            alpr_queue
2024-09-28 15:08:26: ** Runtime:          python3.9
2024-09-28 15:08:26: ** Runtime Location: Local
2024-09-28 15:08:26: ** FilePath:         ALPR_adapter.py
2024-09-28 15:08:26: ** Start pause:      3 sec
2024-09-28 15:08:26: ** Parallelism:      0
2024-09-28 15:08:26: ** LogVerbosity:
2024-09-28 15:08:26: ** Platforms:        all,!windows-arm64
2024-09-28 15:08:26: ** GPU Libraries:    installed if available
2024-09-28 15:08:26: ** GPU:              use if supported
2024-09-28 15:08:26: ** Accelerator:
2024-09-28 15:08:26: ** Half Precision:   enable
2024-09-28 15:08:26: ** Environment Variables
2024-09-28 15:08:26: ** AUTO_PLATE_ROTATE            = True
2024-09-28 15:08:26: ** CROPPED_PLATE_DIR            = <root>\Server\wwwroot
2024-09-28 15:08:26: ** MIN_COMPUTE_CAPABILITY       = 6
2024-09-28 15:08:26: ** MIN_CUDNN_VERSION            = 7
2024-09-28 15:08:26: ** OCR_OPTIMAL_CHARACTER_HEIGHT = 60
2024-09-28 15:08:26: ** OCR_OPTIMAL_CHARACTER_WIDTH  = 30
2024-09-28 15:08:26: ** OCR_OPTIMIZATION             = True
2024-09-28 15:08:26: ** PLATE_CONFIDENCE             = 0.7
2024-09-28 15:08:26: ** PLATE_RESCALE_FACTOR         = 2
2024-09-28 15:08:26: ** PLATE_ROTATE_DEG             = 0
2024-09-28 15:08:26: ** REMOVE_SPACES                = False
2024-09-28 15:08:26: ** ROOT_PATH                    = <root>
2024-09-28 15:08:26: ** SAVE_CROPPED_PLATE           = False
2024-09-28 15:08:26: Started License Plate Reader module
2024-09-28 15:08:26: Installer exited with code 1
2024-09-28 15:08:26: ALPR_adapter.py: Traceback (most recent call last):
2024-09-28 15:08:26: ALPR_adapter.py:   File "C:\Program Files\CodeProject\AI\modules\ALPR\ALPR_adapter.py", line 11, in <module>
2024-09-28 15:08:26: ALPR_adapter.py:     from ALPR import init_detect_platenumber, detect_platenumber
2024-09-28 15:08:26: ALPR_adapter.py:   File "C:\Program Files\CodeProject\AI\modules\ALPR\ALPR.py", line 17, in <module>
2024-09-28 15:08:26: ALPR_adapter.py:     from paddleocr import PaddleOCR
2024-09-28 15:08:26: ALPR_adapter.py:   File "C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\lib\site-packages\paddleocr\__init__.py", line 14, in <module>
2024-09-28 15:08:26: ALPR_adapter.py:     from .paddleocr import *
2024-09-28 15:08:26: ALPR_adapter.py:   File "C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\lib\site-packages\paddleocr\paddleocr.py", line 21, in <module>
2024-09-28 15:08:26: ALPR_adapter.py:     import paddle
2024-09-28 15:08:26: ALPR_adapter.py: ModuleNotFoundError: No module named 'paddle'
2024-09-28 15:08:26: ** Module ALPR has shutdown
2024-09-28 15:08:26: ALPR_adapter.py: has exited
2024-09-28 15:08:29: Module ALPR started successfully.
