DJBWSM
@MikeLud1 Help. Now spent 3 days ripping my hair out.
I have read the 52 pages on this post looking for answers and tried every suggestion you recommend to others. Still I cannot get APLR working with my GPU. Works fine with CPU but is slow.
This is what happens the first couple of time then nothing is found.
Status Page:
NVCC Output:
Server version: 2.6.5
System: Windows
Operating System: Windows (Microsoft Windows 10.0.19045)
CPUs: Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz (Intel)
2 CPUs x 8 cores. 8 logical processors (x64)
GPU (Primary): GRID P100-16Q (16 GiB) (NVIDIA)
Driver: 538.33, CUDA: 11.8.89 (up to: 12.2), Compute: 6.0, cuDNN: 8.9
System RAM: 32 GiB
Platform: Windows
BuildConfig: Release
Execution Env: Native
Runtime Env: Production
Runtimes installed:
.NET runtime: 7.0.20
.NET SDK: 7.0.410
Default Python: Not found
Go: Not found
NodeJS: Not found
Rust: Not found
Video adapter info:
NVIDIA GRID P100-16Q:
Driver Version 31.0.15.3833
Video Processor GRID P100-16Q
System GPU info:
GPU 3D Usage 0%
GPU RAM Usage 2.3 GiB
Global Environment variables:
CPAI_APPROOTPATH = <root>
CPAI_PORT = 32168
System: Windows
System RAM: 32 GiB
Platform: Windows
Runtimes installed:
.NET SDK: 7.0.410
Go: Not found
NodeJS: Not found
Rust: Not found
Video adapter info:
System GPU info:
GPU 3D Usage 0%
CPAI_PORT = 32168
Status Page:
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\Dan\AppData\Roaming
CLIENTNAME=DESKTOP-0S742NF
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=BLUEIRIS-VM
ComSpec=C:\Windows\system32\cmd.exe
CUDA_PATH=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8
CUDA_PATH_V11_8=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8
DriverData=C:\Windows\System32\Drivers\DriverData
FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING=Default
HOMEDRIVE=C:
HOMEPATH=\Users\Dan
LOCALAPPDATA=C:\Users\Dan\AppData\Local
LOGONSERVER=\\BLUEIRIS-VM
NUMBER_OF_PROCESSORS=16
OneDrive=C:\Users\Dan\OneDrive
OS=Windows_NT
Path=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\libnvvp;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\dotnet\;C:\Users\Dan\AppData\Local\Microsoft\WindowsApps;C:\Users\Dan\.dotnet\tools;C:\Program Files\NVIDIA\CUDNN\v8.9\zlib\dll_x64;C:\Program Files\NVIDIA\CUDNN\v8.9\bin;C:\Users\Dan\AppData\Local\Microsoft\WindowsApps;C:\Users\Dan\.dotnet\tools
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 79 Stepping 1, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=4f01
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
SESSIONNAME=RDP-Tcp#0
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\Dan\AppData\Local\Temp
TMP=C:\Users\Dan\AppData\Local\Temp
USERDOMAIN=BLUEIRIS-VM
USERDOMAIN_ROAMINGPROFILE=BLUEIRIS-VM
USERNAME=Dan
USERPROFILE=C:\Users\Dan
windir=C:\Windows
HOMEDRIVE=C:
HOMEPATH=\Users\Dan
OS=Windows_NT
PROCESSOR_LEVEL=6
PROMPT=$P$G
SystemDrive=C:
USERNAME=Dan
windir=C:\Windows
NVCC Output:
Code:
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:41:10_Pacific_Daylight_Time_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
Module 'License Plate Reader' 3.1.0 (ID: ALPR)
Valid: True
Module Path: <root>\modules\ALPR
Module Location: Internal
AutoStart: True
Queue: alpr_queue
Runtime: python3.9
Runtime Location: Local
FilePath: ALPR_adapter.py
Start pause: 3 sec
Parallelism: 0
LogVerbosity:
Platforms: all
GPU Libraries: installed if available
GPU: use if supported
Accelerator:
Half Precision: enable
Environment Variables
AUTO_PLATE_ROTATE = True
CROPPED_PLATE_DIR = <root>\Server\wwwroot
MIN_COMPUTE_CAPABILITY = 6
MIN_CUDNN_VERSION = 7
OCR_OPTIMAL_CHARACTER_HEIGHT = 60
OCR_OPTIMAL_CHARACTER_WIDTH = 30
OCR_OPTIMIZATION = True
PLATE_CONFIDENCE = 0.7
PLATE_RESCALE_FACTOR = 2
PLATE_ROTATE_DEG = 0
REMOVE_SPACES = False
ROOT_PATH = <root>
SAVE_CROPPED_PLATE = False
Status Data: {
"inferenceDevice": "GPU",
"inferenceLibrary": "CUDA",
"canUseGPU": "true",
"successfulInferences": 0,
"failedInferences": 0,
"numInferences": 0,
"averageInferenceMs": 0
Started: 31 May 2024 8:01:44 PM GMT Standard Time
LastSeen: 31 May 2024 8:03:15 PM GMT Standard Time
Status: Started
Requests: 42 (includes status calls)
Installation Log
2024-05-31 18:18:02: Installing CodeProject.AI Analysis Module
2024-05-31 18:18:02: ======================================================================
2024-05-31 18:18:02: CodeProject.AI Installer
2024-05-31 18:18:03: 78.5Gb of 261Gb available on
2024-05-31 18:18:03: General CodeProject.AI setup
2024-05-31 18:18:03: Creating Directories...done
2024-05-31 18:18:03: GPU support
2024-05-31 18:18:04: CUDA Present...Yes (CUDA 11.8, cuDNN 8.9)
2024-05-31 18:18:04: ROCm Present...No
2024-05-31 18:18:06: Checking for .NET 7.0...Checking SDKs...All good. .NET is 7.0.410
2024-05-31 18:18:13: Reading ALPR settings.......done
2024-05-31 18:18:13: Installing module License Plate Reader 3.1.0
2024-05-31 18:18:13: Installing Python 3.9
2024-05-31 18:18:29: Downloading Python 3.9 interpreter...Expanding...done.
2024-05-31 18:19:12: Creating Virtual Environment (Local)...done
2024-05-31 18:19:13: Confirming we have Python 3.9 in our virtual environment...present
2024-05-31 18:19:16: Downloading ALPR models...Expanding...done.
2024-05-31 18:19:16: Copying contents of ocr-en-pp_ocrv4-paddle.zip to paddleocr...done
2024-05-31 18:19:16: Installing Python packages for License Plate Reader
2024-05-31 18:19:16: [0;Installing GPU-enabled libraries: If available
2024-05-31 18:19:21: Ensuring Python package manager (pip) is installed...done
2024-05-31 18:19:56: Ensuring Python package manager (pip) is up to date...done
2024-05-31 18:19:56: Python packages specified by requirements.windows.cuda11_8.txt
2024-05-31 18:22:11: - Installing PaddlePaddle, Parallel Distributed Deep Learning...(✅ checked) done
2024-05-31 18:27:52: - Installing PaddleOCR, the OCR toolkit based on PaddlePaddle...(✅ checked) done
2024-05-31 18:28:03: - Installing imutils, the image utilities library...(✅ checked) done
2024-05-31 18:28:08: - Installing Pillow, a Python Image Library...Already installed
2024-05-31 18:28:12: - Installing OpenCV, the Computer Vision library for Python...Already installed
2024-05-31 18:28:47: - Installing NumPy, a package for scientific computing...Already installed
2024-05-31 18:28:47: Installing Python packages for the CodeProject.AI Server SDK
2024-05-31 18:28:53: Ensuring Python package manager (pip) is installed...done
2024-05-31 18:29:03: Ensuring Python package manager (pip) is up to date...done
2024-05-31 18:29:03: Python packages specified by requirements.txt
2024-05-31 18:29:08: - Installing Pillow, a Python Image Library...Already installed
2024-05-31 18:29:13: - Installing Charset normalizer...Already installed
2024-05-31 18:29:31: - Installing aiohttp, the Async IO HTTP library...(✅ checked) done
2024-05-31 18:29:43: - Installing aiofiles, the Async IO Files library...(✅ checked) done
2024-05-31 18:29:53: - Installing py-cpuinfo to allow us to query CPU info...(✅ checked) done
2024-05-31 18:29:57: - Installing Requests, the HTTP library...Already installed
2024-05-31 18:29:58: Scanning modulesettings for downloadable models...No models specified
2024-05-31 18:29:58: Executing post-install script for License Plate Reader
2024-05-31 18:29:58: Applying PaddleOCR patch
2024-05-31 18:29:58: 1 file(s) copied.
2024-05-31 18:30:49: Self test: Self-test passed
2024-05-31 18:30:49: Module setup time 00:12:41.93
2024-05-31 18:30:49: Setup complete
2024-05-31 18:30:49: Total setup time 00:12:46.69
Installer exited with code 0
Valid: True
AutoStart: True
Queue: alpr_queue
Runtime: python3.9
Start pause: 3 sec
Parallelism: 0
LogVerbosity:
Platforms: all
Accelerator:
ROOT_PATH = <root>
Status Data: {
"numInferences": 0,
Status: Started
Installation Log
I have finally gotten things working on the YOLO side but ALPR has some issues. I am running CPAI 2.6.5 with LPR 3.1.0. I am getting errors every time BI fires off a request to the ALPR module. I have read through this thread and the CPAI docs that point to using specific versions of packages from NVidia to get things working.
