Wired6400
I'm setting up a new Blue Iris system as I've moved... Loving the integration with CodeProject.AI.
My first camera had to be setup to be a license plate reader just because. I've got a restricted space driveway that forces cars to follow a single lane path through a fence, so it's perfect to put the camera on that location. I've also highlighted only the areas that will have a license plate as a zone to reduce processing time by the AI system. It all works brilliantly (though I'll be getting a different camera so it'll work at night). I'm getting 99% confidence on all day plates.
I'm having three issues though:
Also, don't laugh at the times - I'm using this computer to test and validate things before I move Blue Iris to it's eventual computer that's not yet been built.
- I don't get the plate associated with the clip. In my review of the feature, the plate is supposed to be searchable in the clip area, but it's not. I've captured plates with "Only for confirmed vehicle alerts" checked and unchecked (I don't always end up having AI say there is a car in the image since the zone is focused on where the plates are, so only sections of the car are seen). My configuration for AI On this camera is:
- My understanding is that Blue Iris will essentially send each still to AI until it gets above the threshold of confidence (in my case 80%), then AI will no longer process the rest of the images of the clip. This makes sense to minimize additional processing time that's not needed. In my case, it is continuing to process every image - and with the current NVR computer I'm using, it blows out the time for processing fairly significantly.
- Finally, you can see in the image above, the first few images don't find a plate - the front of the car is all that's in the zone. However, once I get to 99% confidence, I'd have thought all the remaining images in the clip would be skipped. I suspect that they aren't simply because the AI model has only found a "DayPlate" and not an "object", but I'm not entirely certain.
