Blue Iris and CodeProject.AI ALPR
Maryland unfortunately has many plates with small letters stacked on top of each other like the picture below. I can never get a correct reading when these plates come through. Has anybody else had success with similar plates? Is this something that should be added into the model training or is there something else I can try? 722133BB-A1D3-4E29-BBA1-82690A720515.jpeg
  • Angry
Reactions: Nunofya
Hi all,
I've implemented the LPR in my Blue Iris setup using SenseAI, which seems more maintainable and fully local, if compared to my previous setup, that was using a PY script to call Plate Recognizer ALPR Server. All is working correctly, but the SenseAI OCR is not as precise and reliable as the PR server. This is resulting in wrong plates number returned, with an high percentage, from the same cams used with my old script and that were working perfectly with PR OCR.
Is there anyway to improve the OCR module of SenseAI ?
Or should I go Back to Plate Recognizer APIs? BTW, I think I could be able to modify the SenseAI scripts to call PR rather than internal OCR, which I wouldn't do, for maintenance implications.
Thank you!
Any chance this could be added to the arm64 versions of Codeproject? I am playing around with a Orange Pi 5 which is is maybe 80% faster than a RPI 4. I am trying to compare that to my old Xeon server running windows.
I also might run this on an M1 Mac which can run ARM docker files... That processor appears to really haul ass..
That said, all my benchmarking shows the oldschool xeon E3s running codeproject.ai on windows as being the fastest still?
I just bought a Orange Pi 5 and was play with it. I have AI working outside of CodeProject.AI next is to make a module CodeProject.AI. I am not sure when I will have it done, but I am working on it
Awesome!!! It looks like it is a good SBC which is better than an RPi4, but given the shortage prices is pretty competitive.
Let me know how it works out. Did you get an NVME board for it? Which size memory did you get?
There is some sort of TPU (Tensor Flow Processing Unit) on there. I am not sure if that can be utilized. I think CodeProject uses Tensor flow. Docker was natively installed on their ubuntu install- so I was able to get the docker ARM image working..
I am trying to run CP AI on a separate machine than by BI. I've got 2 main problems at the moment. 1) I do not show any plates whatsoever. I only see DayPlate and NightPlate. 2) If I try to read a plate image, it only works very slow on CPU, not on GPU. I always get 'No predictions returned.' I've read through this forum but so far I've not been able to find a good solution. I've read a bit about the CUDA version and downgrading but not sure if I need to do that, or how. If it is the GPU, I will just upgrade it. I wanted to run this on my BI machine but it doesn't have a GPU and is a slim pc. Appreciate the help in advance.
Can you post the below screenshot
It looks like there is an issue with the ALPR module, you can try uninstalling it then reinstall or wait till CPAI v2.1.0 comes out. Which might be today.
I tried reinstalling but get the same result. I will wait for the next version and test once it is available.
Once the new version comes out folow the below steps to install
1. Uninstall CP:AI
2. Delete the Codeproject Directory completely - "C:\Program Files\Codeproject"
3. Delete "C:\ProgramData\CodeProject"
4. Restart The Computer
5. Reinstall CodeProject along with the modules that you wish to install.
6. Restart Computer one more time
7. Run BI and CP:AI
@MikeLud1 - I'm in Australia and using the license plate module with a high percentage of success however I am getting a few anomalies.. Are you interested in training the AI module further by having us common folk like myself sharing licence plate pictures that have these issues via PM or via this thread? Or is this not something you are keen on?
Cheers
