Hello all,
I am giving Blue Iris built in AI another shot after learning some Nvidia control panel tricks (specifically to force no fallback to system memory for BlueIris.exe service which forces the use of my RTX3050 vram instead of system memory). One issue that I can not figure out is that TensorRT reverts to DirectML after every reboot. I have clean installed the latest Nvidia studio driver for my RTX3050, I have reinstalled Cuda toolkit 12.4 and check that the PATH was correct in env variables, I have reinstalled Blue Iris from scratch, I have added a service dependency to the BlueIris system service so that it waits for the NVidia service to fully start before starting itself. Nothing I have tried has remedied the issue. It works when I manually set to TensorRT after boot. I run Nvidia-smi, and I get the blueiris.exe service at "Type C" and according to system monitor my RTX3050 is being used as well as its vram shows useage. So it doesn't appear that blue iris is falling back to DirectML at all..... again until after I reboot the machine.
