Blue Iris 4 to 5 Migration Guide
hotbrass
Joined
Mar 16, 2016
Messages
99
Reaction score
12
I am considering purchasing BI 5. I have paid for BI 4 and it works great. Can I keep running BI 4 running, and purchase BI 5 and run it on a separate computer?
gwminor48
Joined
Jul 16, 2015
Messages
3,713
Reaction score
7,275
Location
Texas
Yes, absolutely. I love BI4, it was always very reliable for me. I upgraded to BI5 although I was very happy with BI4 and had no particular reason to upgrade but BI5 has been good too. I don't believe you would be able to use an upgrade to BI5 to put on a different pc while leaving BI4 on the other one but buying BI new would be no problem. I could be wrong, we'll see what others say.
hotbrass
Joined
Mar 16, 2016
Messages
99
Reaction score
12
Not upgrading. Buying a whole new license with BI5.
wayner
Joined
Apr 20, 2017
Messages
47
Reaction score
8
Location
Toronto
Is it worth upgrading to V5? I tried upgrading and I don't see much difference.
I am a bit disappointed that the software didn't switch to more of a Windows Standard UI. Is there a good reason why BI deviates a lot from the Windows standard, even for little stuff like the icons in the top right corner of the window for minimize, window and close?
fenderman
Staff member
Joined
Mar 9, 2014
Messages
36,848
Reaction score
21,302
There are may added features and functions most listed in the help file "whats new" and "update notes" sections. If that is not worth 30 bux to you, I dont know what is.
Why are you disappointed with the UI after purchase, its was available for you to see and test before hand. If the icons bothers your OCD try emailing support and see if he can accommodate your disability, otherwise, there are 50 other vms options to choose from. The developer is one guy and does things his way or the highway.
gtj
Joined
Sep 13, 2017
Messages
114
Reaction score
23
Apologies if this has already been answered but I couldn't find any definituve info.
I'm running BI 4.0 for years and now that version 5.0 seems to have matured, I'm thinking to migrate to it.
Should I buy a new lisence or should I just install 5.0 and apply the key of my existing one?
Many thanks and kind regatds
mikeynags
Joined
Mar 14, 2017
Messages
1,039
Reaction score
942
Location
CT
I believe the old key won’t work with V5. I went ahead and purchased separately. Also, my support had expired so I wasn’t eligible for an upgrade.
Reactions: gtj
gtj
Joined
Sep 13, 2017
Messages
114
Reaction score
23
Thank you so much for the response.
My support has expired too so I guess I'll have to buy a new lisence.
mikeynags
Joined
Mar 14, 2017
Messages
1,039
Reaction score
942
Location
CT
It’s definitely worth the price you are paying. I actually built a new machine for it so the V4 machine is now a backup machine and V5 runs on the new pc.
Reactions: gtj
eggzlot
Joined
Jun 23, 2015
Messages
113
Reaction score
27
sorry in advance - did not read all 19 pages. I did try and search - found others with similar issues but responses were a bit too technical for me.
Started to finally migrate BI 4 to BI 5. Got past the Visual Studio issue and installed those files. now AVG is telling me BI 5 has malware. Ken from BI says its clean and I should contact AVG which I plan to do. Ken told me to check the digital certificates, again I am not super techy, so I read online how to view it, but I do not know what I am checking.
With AVG I can over ride their recommendation and still install the software, but again that gives me great concern.
in 2020 - shouldn't it be easier to install paid software vs having to go to multiple sites to get multiple .exe files and backdoor security programs? I've waited about 6 months to upgrade, figured all the kinks would be ironed out by now?
ljw2k
Joined
Jun 9, 2014
Messages
1,495
Reaction score
2,282
Location
United Kingdom
Just installed BI V5 coming from 4 and all went smooth no problems whatsoever and loving the Weather widget from Mike, well done and worth every penny.
1.21 jiggawatts!
Joined
Aug 29, 2018
Messages
105
Reaction score
15
Location
toronto canada
"Step 6) Uninstall Blue Iris 4
After Blue Iris 5 is running correctly, you can uninstall Blue Iris 4 just like you would uninstall any other program. When it asks if you want to delete registry entries and activation, click no. Your registry entries will probably be lost anyway. That is why we made a backup. If Blue Iris 5 has suddenly lost activation, restore your backup."
i followed the instructions exactly. everything was fine in blue iris 5 until i followed this step. after removing version 4, i lost all my settings in version 5 and i lost a few months worth of footage in my "stored" folder, the only thing that wasn't deleted was the protected footage and footage that was about a day old.
i was able to restore the settings in version 5 with the exported backup file.
looney2ns
Joined
Sep 25, 2016
Messages
15,685
Reaction score
23,135
Location
Evansville, In. USA
Shut down BI, Delete the Database folder, then restart BI. DB will rebuild and your "lost" clips should be back.
OICU2
BIT Beta Team
Joined
Jan 12, 2016
Messages
843
Reaction score
1,399
Location
USofA
Hi all, I finally got around to trying the upgrade to 5. Everything went ok except it says I am not licensed now, I tried importing the backup and it still says no license. Where do I go from here?
Edit: Nevermind on the license, I re-entered my previous license and it is now licensed.
How about the web gui? That seems to not be working, do I need to restore something for that ?
fenderman
Staff member
Joined
Mar 9, 2014
Messages
36,848
Reaction score
21,302
See instructions in the first post. It should be fixed with the new installer, but there are instructions on how to fix it.
OICU2
BIT Beta Team
Joined
Jan 12, 2016
Messages
843
Reaction score
1,399
Location
USofA
Got it, had to change the path. The installer did not do it.
Rockford622
Joined
Feb 19, 2016
Messages
185
Reaction score
33
Just updated my BI from 4 to 5 and here are a few of my observations:
Followed the instructions on the first page exactly.
1) Exported everything (general settings and each camera).
2) BI5 install went fine. Did this and rebooted.
3) Uninstalled BI4. Specifically said NO to uninstalling registry stuff.
4) Opened up console on BI5. For some reason, it needed the original key. Found this and pasted it in. Needs the original key, not an upgrade/maintenance key.
5) BI5 was now in default settings mode. Strange since I said NO to deleting registry stuff. Imported my general settings export .reg file and everything came back to life. Cameras were now all there.
6) Had to remap location of \www\ directory since my general settings export .reg file was from v4. Did this and the now the webserver worked, no problem.
Just an FYI, this may be mentioned in this thread somewhere, but it is worth stating again. If you run BI as a service and you have BI move your files to a NAS, then you might have modified the Blue Iris Service to logon as a user other than the "local system" user. You will need to add those credentials again for the BI5 version of then Blue Iris Service since it is new. Otherwise, you will probably wonder why your local drive is filling up with clips and not being moved to your NAS.
BI5 seems to be easier on the CPU so far, which is a plus!
bohemian
Joined
Apr 9, 2017
Messages
13
Reaction score
3
Took the plunge (again) and this time things went very smoothly. Only real issues were re-adding my support key and changing the service creds (again) so that BI ran as a named user. Other than that, a much better experience this time round.
But I won't be an early adopter for BI6, that's for sure!
JayS_IPCams
Joined
Oct 30, 2018
Messages
72
Reaction score
16
Location
Washington
Strange that the installer hasn't fixed these issues yet :(
Is it worth the upgrade?
Top
