BI6 new built in AI beta 6.0.1.0
The below change should fix it. One recommended change is to clone this camera and use the Clone camera just for license plate detection and the Clone Mater camera for object detection.
Did you download and install the models, also select whatever GPU you have
Check Primary object detection, delete object:0,license-plate, and uncheck Override global list and Additional models
Delete DoNotCancel
Thank you Mike Let me try your settings Im sure they will work better than what I had. Thank you once again for taking the time to reply
Reactions: MikeLud1
Delete DoNotCancel
Hey Mike, After deleting Codeproject do you still use the Alert tab, then On Alert setting for the ALPR Database?
