BI won't start after latest update!
PRWL
Dec 10, 2025
2
CANADA
After updating my BI instance to 6.0.0.1 (I believe,) Blue Iris is no longer launching, and I can't set up my infrastructure. I already tried restarting the service, or anything basic. Please help!Screenshot_20251210_211259.png
Do you have the user and password set correctly for the service, it must be a local account with administrator privileges? Is this on Windows 11, are you using a Microsoft PIN to login to your PC if so then that is possibly your problem! What do you mean by your infrastructure, are you referring to your cameras ???
The Blue Iris service is correctly configures with a local administrator account, and was working fine before the update. By infrastructure I mean I am unable to use my server infrastructure that relies on BI.
Thanks!
Did you reconfigure the new BI service with the user and password, it needs to be setup again after the upgrade to BI 6, the old service for BI 5 would have been removed; sorry for the possibly redundant questions!
