BI configuration for IPC-T54IR-ZE-S3
chain
Joined
Feb 29, 2020
Messages
30
Reaction score
3
Location
great white north
I'm trying to setup these camera IPC-T54IR-ZE-S3 with BI using Get ONVIF events, under Trigger zones I have selected ONVIF and External. The issue that I'm having is one camera get the Main /Sub stream profiles MediaProfile_Channel1_MainStream /cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif /\ Sub /cam/realmonitor?channel=1&subtype=1&unicast=true&proto=Onvif
The second camera Stream profiles Main (default) / and Sun (none) select (default)
What is causing the issue with the second camera cannot pickup what the first camera is showning ?
wittaj
Joined
Apr 28, 2019
Messages
25,516
Reaction score
49,783
Location
USA
Simply copy the main and sub profiles into the 2nd camera.
It could be a firmware issue or the way you brought the camera into BI.
wittaj
Joined
Apr 28, 2019
Messages
25,516
Reaction score
49,783
Location
USA
The clone could be what did it.
I would just delete the camera and add new
Joined
Aug 3, 2015
Messages
3,850
Reaction score
12,386
Location
Charlotte
If you're using anything other than the admin account to detect the camera, the auto-detect probably won't register Onvif signal paths correctly. I ran into this last week setting up a new boobie-cam.
wittaj
Joined
Apr 28, 2019
Messages
25,516
Reaction score
49,783
Location
USA
In the camera GUI, Under Network > Access Platform, turn onvif authenticator off.
chain
Joined
Feb 29, 2020
Messages
30
Reaction score
3
Location
great white north
I've start to notice that blue iris is freezing with the camera running Codeproject AI with version 5.7.6.8. What version should I be running?
tul9033
Joined
Jul 18, 2014
Messages
34
Reaction score
10
Location
Tulsa, OK
Had the same problem on one of my IPC-T54IR-ZEB-S3. The others had ONVIF authenticator on, but you post worked on the lone wolf. Thanks!
Top
