What are you exposure settings for daytime? Are you using 'customized range' for the shutter speed?
Something is strange or my setting need adjustment..
Attached as you can see picture from today in daylight mode. The picture are capture around 11am and 2pm. and now at 5:21pm the picture is not clear is it because the sunlight is going down and not so bright? or is he walking too fast? the picture is blurr. anyone know how to fix this?
thank you
thank you!! let me try adjusting the setting to manual and see how it goes.. thank you!!You will have to experiment with some of the settings. But having the exposure mode to auto will give you heartburn as the daylight gets low. Also as @bigredfish stated, you might have to cut down the 3D NR grade.
My daytime settings for that set is:
thank you!! i'll try to lower it in the daytime and see if its better..You should be able to be under 30 for NR in daytime. Go as low as you can before it is a noisy mess. Will also add some details back to some of those faces.
