Best indoor and outdoor cameras from Dahua ?
I'm not as familiar with other brands, but I think the 3449 would be fine for the entrance to your shop. Place no more than 7-8ft high and 8ft from the door would be the sweet spot
yes the 5442T-ZE would be a good choice.
Note its not meant to be treated like am PTZ, I wouldnt adjust focus every single day or you will lose some life expectancy. But every once in a while sure.
Reactions: JDreaming
I have one more question before placing the order. Will I get significantly better daylight image quality if I go with the 5442TM-ASE-S3 4MP IR Fixed-focal Eyeball WizMind Network Camera (112°) with a 2.8mm lens instead of the 3449H-AS-PV-PRO WizColor WizSense TiOC 4MP Eyeball IP Camera (111°) with the same lens?
I’ve been spending quite a bit of time on this forum lately, and I’m starting to second-guess some of my choices for the front of the market setup — you guys clearly know your stuff and are very passionate!
Daytime image quality is especially important in my case, since we have several refrigerators and ice cream freezers outside that need surveillance during the day . So if the 5442 S3 provides noticeably better image quality in daylight, I’d definitely prefer that over the TiOC version, even though the strobe and extra features are cool.
Also, I should mention that the current camera setup is really bad — honestly, I don’t think it could be worse. The person who installed it seemed more focused on hiding it than on actually covering the area properly. To make matters worse, the camera itself is just an old interior model we had lying around the house — probably over 12 years old — connected to a DVR system. The image quality is, as expected, very poor, and nowhere near what we need for outdoor monitoring.
For the upgrade, I’m planning to move the new camera at least 1 meter closer to the entrance — maybe even place it right above the entrance door, centered on the front of the market. It’s a fairly wide area, so I’m curious if the 2.8mm lens will still give me good coverage from that position.
Also, just to add: there is already some ambient light at night from the drinks refrigerators that run 24/7 with their LED lighting and the street lights are pretty strong, so it’s far from completely dark
I’ll attach a photo from the current camera to give you a better view of the situation. Please also check the previous pictures I posted to get the full context. Thanks a lot!
Front door?
Yes the 3449 Pro 3.6mm should be fine there. I’d like it lower but ok
Thanks a lot! Yes, I’ll definitely install the new one lower and a bit more to the left. I’m concerned that if I place it directly above the door, it won’t fully capture the side refrigerators. That’s why I’m considering the 2.8mm
Do you think there’s no noticeable difference in daylight video quality between the two models? I came across some discussions suggesting that the 5442 S3 Eyeball performs much better in daylight, while the 3449 Pro is better in total darkness. But since it’s far from pitch black at night in that area—there’s actually plenty of light—that’s what made me rethink the problem and thought that it would be better to ask one more time, as i realised that i forgot to mention that it's far from complete darkness in the night-time and the daylight video quality is also very important.
generally speaking that’s correct. The image quality imho is slightly better on the 5442 in IR and IF you have enough light for color (it takes more than most people think)
*Get people to show you actual images of the 5442 in color at night with movement. Talk is cheap
Again it comes down to choices:
  • do you need color at night? The 5442 needs a LOT more light to run color at night and maintain a blur free image.
  • do you need/want the ability for the camera to auto adjust from B&W/IR to Color with its own onboard white LEDs? 3449Pro
  • Do you want good two way talk and better mic’s? 3449 Pro
Looks to me like it needs to move closer to the door to get the top of the drink case out of the view
Ideally, there should be at least 2 cameras at the entrance. One facing from the door out just above it to catch traffic coming into and another facing the door to capture traffic coming out of the store
