Baby Monitor Recommendation
Tiny cam has the same issue with high bit rate, but you can run in low bandwidth mode
I think it would be great if the DS-2CD2532F-IW had an audio alert option. Would be a incredibly good baby camera that you can then use as a proper cam at a later date.
All,
In case anyone finds it useful, I did a first run test with this battery:
www.amazon.com/gp/product/B00B45EOYS
I hooked up the TP-Link TL-WR802N router to its USB port and the Hikvision 2432 to the DC output port. I then linked the camera to the router, connected to the camera's web interface, and started streaming high-def video at the highest bit rate. I set up a reoccurring ping to the router and then checked how long it kept responding to pings. This was basically a "worst case" scenario for power usage, but I was pleasantly surprised to see that the camera streamed for just over 16 hours before the battery ran out of power.
I also noticed that I managed to buy the older (and more expensive) generation battery, so I'll be returning it and purchasing the second generation battery which supposedly has about 15% more power and two more USB ports. That should improve the run-time as well.
Thanks everyone!
Thanks @metro, I did find your posts useful. I ordered the TL-WR802N travel router that you linked to and may order that 2nd gen Anker battery. I won't be using it as a baby monitor, but will use it to demo a spare Hik 2432 that I'm not using right now. A friend of mine has been wanting me to bring a IP camera over to his house to demo it to some of his neighbors. This would be an ideal setup. The fewer cables the better. :peaceful:
I use a 2432. I was also concerned about ir. Maybe no big deal but not enough confidence to say that for sure. What I did was put a bunch of layers of masking tape over the ir light. A small enough amount gets through that in a closed off room I can still see quite well what is going on. Untapped the ir lights on these things are so darn powerful and you just don't need it for a baby room imo. Another thing I did was tape over all signal lights so that the camera looks dark. This way there was no inclination to just stare at the thing anyway.
prior to this I used a dropcam and did not shield its visible ir lights, but they wee way less powerful than on the cube.
Reactions: metro
Over two years ago when I got my 2432s I complained to Hikvision first thing about the activity lights and whether they could disable them via firmware update... the only response I got was "we don't support your cam... blah blah"
Reactions: metro
