AXIS P55/Q60 Multi-connector cable - pinout?
Hi Damien,
Sorry, but the tagging of audio out pins was made by Lehrian above in the thread - I just edited them in. But to zoom in on the problem at hand: the documentation for the P5534 only mentions existence of audio out, and the pics of the (expensive) cable only shows DIN-jacks for audio in/out (below).
One way to test the rig could be to test the following permutations: A. Both audio out (9, 10) connected to GND + signal in (left or right) on a pair of headphones. B. Pin 9 and GND (14) connected in same way to headphones. C. Pin 10 and GND (14) connected in same way to headphones. You could probably hold the wires to the 3,5 mm male plug of the headphones, just for testing. Pick the working combination.
But if you get audio out, what is really the problem - curious here...
Alright. Pin 9 is the speaker output, Pin 10 is the speaker ground from the tests I just completed.
Nice! According to the documentation for the camera, this should be a signal fit for an amplifier!
Good luck with your project! Since I have one such camera like this, it'd nice to hear what you do with it. My cam will be for watching wildlife in a cottage...
So! I had done some crazy advanced stuff.
I had modified the configuration of my camera to allow for 15 degree tilt from the horizon!
Here are screenshots of what I have and have done.
First, I started with binwalk with extract; And started to dig through. I will not provide screenshots of it and lets get to the point.
I must mention; the cameras filesystem is NORMALLY read-only, which can be read-write by running
Code:
mount -o remount,rw /
I had executed
Code:
find | grep "ptz"
on the camera itself over SSH and put the result into notepad:
I tried to have 5 degrees and I calculated the steps for it to work... somewhat
The result I got? unreliable tilting positioning.
So; This is what I did instead, went from 5 degrees to 15 degrees, set the min to step of 0 and max of the total number of steps, in this case, being 38400.
On a side-note; I realized that it will possibly be limited by another config; For which I found this:
I edited that config along with another one before I continued on.
Here's that config I am referring to:
So, I decided to reboot my camera, BUT it MUST have its firmware re-flashed (red flashing light, aka recovery mode) after mounting the filesystem as read-write and modifying the files and rebooting, But there is a workaround! I found there is a thing at
Code:
/operator/custom_firmware.shtml
which creates a copy of whats on the camera flash BUT also shuts down most camera processes while doing so, and when it finishes, starts everything back up; Including the new PTZ configuration. Only by then should you reboot the camera and get presented this:
The workaround? Use the file your camera generated with the custom firmware tool.
And once that was done, Bam! 15 degree tilt being listed and physically goes to 15 degrees with precision. The mechanical limit is 20 degrees.
So, That parts done, finally! So I dig deeper to find anything interesting.
Starting with the camera module:
The camera block supposedly is a Hitachi SC-110; which matches with what I have in mine.1755044925992.png
I was able to send commands to the camera with the cam_upgrade utility to directly control the camera block itself
Cool! But is there anything else? YUP!
I found out about what the temperature sensor is:
And here is the TMP100 Datasheet.
Found the messages that show on the overlay when stuff happens, Which could be customized to say something else!
Of course this is binary, but still, pretty cool to see that header to verify what it is!
And these are commands that get sent to the camera for configuration.
Heres one reference for some commands:
I also found this, which is interesting to say the least.
But that's all what I have to show at the moment!
A little of a off-topic part but I felt like it would be worth putting the work to post it in this thread!
good day,
i also have an axis p5534 that i want to mount a capsule microphone to. the question is which microphone is compatible? any capsule microphone? i connected to pin 11 and pin 14
GND but it doesn't work. can you help me with some advice?
thank you and i appreciate any help....
good day,
Make sure your NVR, or software is configured to use the audio from the camera, make sure that's setup and enabled first.
For the camera, make sure the audio is enabled on the camera itself for streaming:
Save and continue.
Capsule microphones require power to work, unless its amplified already (for example a mic+speaker combo box has its own amplifier), is your settings for audio as follows?
make sure to see if "Microphone power" is on and save.
it will pretty much work with any microphone, just as long as it doesn't need something like phantom power or the like.
If you done one or both of those, you may need to restart the stream from the camera to get audio.
Reactions: Boseee
Save and continue.
thank you for the answer
but in the web interface I checked audio and still the mic level does not react. I also changed 3 microphone capsules but in vain I also tried with a microphone from an axis 1014 but nothing.I restarted the camera, the configuration is as you answered, I also measured pin 11 -3.3V 14-GND
tomorrow I'll try with an axis 5512
I also tried with the P5512 and still no audio signal. I made the settings as you explained...........
thanks for the answer
have a nice day
Reactions: damienwolf07
Hi all,
So, I am the new happy owner of an old P5534 PTZ camera. This camera will be used to watch birds and provide some basic oversight in a small cabin in the woods in the South of Sweden. coomeet 1v1chat
To power the camera, I ordered a cheapo POE Switch from Ali, and - as can be expected, the camera webserver proclaims that the camera hasn't enough power for the PTZ and camera to work. So, my plan is to run the camera from a 24V DC power supply. According to the Axis manual, there is a special cable 5502-491 that apparently contains a multitude of I/O, among them 24V DC and AC in. Trouble is that Axis has not provided the pinout for the actual connector in the camera. Dotworkz has a small patch cable for their enclosures that should do the trick, but it feels like overkill to buy this one since I have a soldering station 1 meter from where I am sitting.
So here the question goes: does anyone have a clue about the pinout used in the internal connector for the P55/Q60 cameras?
I have a hunch that two pins that are internally connected in series with fuses could be the suspects to use for 24V DC in, but perhaps I am mistaken here (see pic).
Any info would be greatly appreciated!
That is a classic "legacy hardware" puzzle. Since the Axis P5534 requires High PoE (IEEE 802.3at) to power both the camera and the PTZ motors, a "cheapo" PoE switch usually only provides 802.3af (15.4W), which isn't enough to move the motors.
You are correct that the 5502-491 multi-connector cable is the official way to provide auxiliary power. While Axis is notoriously protective of their internal pinouts, here is the information compiled from technical datasheets and common "bench repair" knowledge for the P55/Q60 series.
Hi Lehrian,
Actually yes and no. I traced the PCB and came to the conclusion that the two pins marked in the first post are for 24V AC (after the fuses, the traces lead to a bridge rectifier circuit). In my case, I had readily available access to 19V DC (an old Dell charger), and figured that positive goes to either of the two pins in the first pic, and negative to a grounded pin. See pic below. Works perfectly, no need for 24V.
As for the Audio IN, no info. (I would guess that that input pin should lead to a capacitor, but I did not investigate the matter).
But, there are many knowledgeable people on these boards, so let's keep our fingers crossed that some pro can spend 5 mins with an old 5502-491 cable and tell us more.View attachment 203303
thank you, that was really useful.
