![072602 (1).jpg](/data/attachments/11/11787-7fc37d296835ce5ac4f5775cdb9c5de5.jpg)
![072602 (5).jpg](/data/attachments/11/11791-f1ff4d8e2f7cb3a6f26c5c20bd9844a5.jpg)
![072602 (6).jpg](/data/attachments/11/11792-7b6f2175aca447f9abc85004de9746f4.jpg)
![072602 (2).jpg](/data/attachments/11/11788-12cca0a9f4635509524ff1118e692fb7.jpg)
![072602 (3).jpg](/data/attachments/11/11789-7410a26c51b2b364e26901979e9f04fe.jpg)
![072602 (4).jpg](/data/attachments/11/11790-fbb64daafd8702b9f260f914fb7e99b5.jpg)
Upgrade only to upgrade the ROM chip. Chip must be S2L, models must ( YC-110AR, YC-110AR-AU,YC-HD785R-20X,YC-HD785R-20XA) . Upgrade recommendations directly connected to the computer upgrade. Network can not be interrupted.
http://www.aliexpress.com/item/Hot-S...583148851.html
Model number :YC-110AR (IMX322+S2L)
http://s.click.aliexpress.com/e/cWXx4QjA
Model number :YC-110AR-AU (IMX322+S2L)
http://www.aliexpress.com/store/prod...323387569.html
Model number:YC-HD785R-20X (IMX322+S2L)
http://www.aliexpress.com/store/prod...620546202.html
Model number:YC-HD785R-20XA
Store link address
https://ipyunch.aliexpress.com
http://s.click.aliexpress.com/e/bdcxCSec
The upgrade order must first be (IPNC S2l2.0.1_build 20161012152123)
If you not Zoom and then upgrade(UPG_S_Kernel_201609141149)
After the upgrade, if not zoom. Please upgrade (UPG_S_Kernel_201609141149)
other time version only need to upgrade a file(IPNC_S2l2.0.1_build20161012152123) ,20160809--20160914 version needs to upgrade the kernel file(UPG_S_Kernel_201609141149),if not zoom.
