Assistance in settings - 3 area's of plates
These are my daytime but you made good improvement with those last two shots. YMMV each scene and lighting condition is different. You might just roll with those last changes and see how it goes first.
One note on Focus: I use the "Schedule" profile and manually have the camera turn to Night settings 45 minutes BEFORE sunset to insure it has enough light to get a good focus. Thus the "semi-Auto" setting allowing the camera to determine focus withjin a narrow scene.
Many here feel thats a caveman approach and instead use the Day/Night utility or similar with the "Day/Night" profile and a call from BI (I use an NVR) along with Manual focus to try and be more specific to sunset for the change.
Reactions: JDreaming and oxnor
This is definitely a situation where getting an external IR emitter will help. The in-camera IR emitter really isn't powerful enough at that distance. The camera IR might be helping some, but it is not the primary source of illumination. You can tell because the plates are still clearly being illuminated by the car's license plate light (evident by the fact the plates are brighter closer to the light and darker father away from the light). With the right external emitter, the IR will be the primary light source and the plates will have a consistent level of illumination across the entire plate. Plus, you'll still get plates when the car's light isn't bright or perhaps not working at all.
View attachment 182080 View attachment 182081 View attachment 182082 View attachment 182083 View attachment 182084
Thank you, I'll compare and give 'em a go.
Thank you!
Any recommended IR Transmitter you recommend at this distance and FOV?
Ordered from B&H :). I'll continue to slightly tweak the night settings, but likely won't have much of an update until it gets here
thanks all, appreciate the tips.
any more daytime or night time tips, please keep sending 'em!
last update prior to IR... tuned the settings a bit... here is where I'm at prior to IR... readable.. but could be better!
