Lebeter
- May 6, 2014
- 104
- 19
This seems more like a shutter speed problem than a focus problem with my limited photography knowledge. When comparing to those photos with the UPS truck, the truck is actually driving away from the camera allowing subject/plates to dwell in the frame longer vs the angle of these shots where the vehicle is only in the frame briefly. That is why you had better luck with the slow moving trash truck. You could also try moving your birdhouse closer to the street line and aiming it further down the street to get the subject/plate to stay in the frame longer. Have you tried using the fastest shutter speed? Separately, I had a problem with the IR lights reflecting off the birdhouse housing when I built something similar like this, so the camera glass was nearly flush with the birdhouse opening when I was done to get rid of the IR washout. I was stuck boring the hole out of the birdhouse at an angle slightly to get the downward angle I wanted with the camera.
