bump it to 2mp 1080p....as long as you keep the bitrate the same the connection should stay the same.Ok I ran it at bitrate is 2048 and frame rate is at 15fps. and change the resolution to 1280x720 and it works fine for now. The image ratio is small due to the resolution but it can work. Still pretty clear.
Yea. Was thinking of setting this up at my dad too. And I want to have two blue iris apps to connect remotely to two IP address. I don't want to have to change the IP address everytime to connect to each one.What do you mean by two places? two separate blue iris systems?
The app will let you setup connections to as many servers as you want..just select add server, it will retain settings for both.Yea. Was thinking of setting this up at my dad too. And I want to have two blue iris apps to connect remotely to two IP address. I don't want to have to change the IP address everytime to connect to each one.
