Annke WZ500 info
It would appear from the pic there are several possibilities for separating that housing given the angle of the shot and no detail about what's down in the recesses. The slots on each side may well be access to a simple snap/tab fastener method that holds it together.
Are you able to log directly into the working camera(s) WebUI or is access totally dependent on the NVR interface? And out of curiosity, which Sannce NVR do you have?
I've put my WZ500 on the shelf due to the firmware being pure shit without cloud proxy connectivity. I had it working well with Blue Iris and actual direct PTZ control via mouse pointer on the image and it all went south after a reboot. Was never able to recover that capability again and haven't touched it since.
Anyone else have one of these working dependably without needing the constant P2P connection for ONVIF authentication? Everything I've tried suggests cloud connectivity is required for ONVIF authentication to allow certain levels of functionality.
Sannce seem to use generic names.
So Device name is PoE NVR, and the Device Model is 8CH-5MP
I have the camera connected via both wifi and ethernet cable.
Searched for the camera using ONVIF after setting port on both devices to 8999, and it was pretty much plug & play after that.
I can also use the wifi IP assigned to the camera to get to its web interface, using ie addon for chrome or edge in ie mode.
As for opening the top, I cant seem to find any hidden tabs...
And plugging the cable for the LEDs, well several reason depending on the person I guess.
For me I have my camera indoors, and I dont want my neighbours knowing it's there. The red IR LEDS and white LEDs would give away its location.
Also I assume even if you disable the LEDS in the webui, when the camera reboots every night, the LEDs will probably turn on for it's start-up test.
Simply pulling the cable guarantees the LEDS will never turn on for whatever reason.
If you remember how to open the white part of the housing, please let me know.
We are taking them apart, because the firmware is not working correctly. for example, i have zero control over the white lights in my webui. And a single reboot messes up all the settings on top of that.
But i'm about to stop using the device anymore. I've opted to just buy a decent one. The "low" price isn't that low if you consider the hurdles and issues.
Hello friends, I am sending my working link to the camera, maybe it will be useful to someone.
':pass'- your own or blank password
To reboot
To main stream
To sub stream:
led light off:
Hello and thank you for your work and share
I have a Annke camera model I51DW, and I need also to control the white led possible by the curl commands as you got it
But I try to executed this commands:
curl -s --user 'admin:' '192.161.10.241/form/IRset/IRmode=1&c2bwthr=0&bw2cthr=21&Dualenable=0&luminval=50&IRenable=0&IRdelay=3'
Changing the IP address the user and the password, but without success for now
I think that I need to adjust the commands to my camera model, can you please let me know how can I check the Curl commands that i have to execute in order to get this to work?
Thank you in advance for your support and best regards
I have the same camera, mine is the Sannce 51CS (IPC-E2A5Z18-W-B-TY) firmware version V3.2.1-Tuya_230426.
I would like to change the near focus limit, has anyone found a way around that?
As Revo2Maxx mentioned in page 2 of this thread, in the "Megapixel ip camera" browser software in "settings/PTZ function/autofocus focus limit" it only shows 2M and the drop down box is greyed out, even though in the same software I can manually focus as close as about 20 inches when zoomed fully at 20X.
I can then save that perfectly in focus position as a preset, but when I call that preset, the image is in focus for about half a second then it focuses to 2M.
Or even if I could turn autofocus off, I could manually focus and save preset positions.
Has anyone managed to send http commands to Sannce cameras and if so, would this add the option of disabling autofocus or changing the close focus limit?
I can't access the web interface anymore. Am I the only one ? "ERR_CONNECTION_REFUSED"
I'm not getting any notifications anymore (on the official app)...
Welcome to the World of POS cheap cameras.. I have my WZ500 on Bi and after some time I can't access using the App or WebUI but still works in my Bi.. I have to go to the camera and press reset button that is on the wires.. Once reset and setup again. Being the POS that it is the camera for some reason defaults to 10.0.0.2 even though I have tried to set a Static Ip and the camera after reset reports the IP of being 192.168.x.x but can't access it on that IP only on the 10.0.0.2 lol.. So I just leave it there. Anyway I setup with Same Password I had in Bi and it comes back online. I will admit I have to search again and setup to get the presets to work again in Bi oddly only camera that acts this way..
So yeah reset button time..
Look at the first page of this discussion for the answers how to setup blue iris to work with PTZ of this camera.
Thanks so much for quick reply!
Strangely enough I did not have to go in to the curl thini... ended up setting up my annke to >
And that appear to work!
But I have problem with stream now :/
it appear that I'm getting quite bad bitrate, does any1 have any idea how to get better bitrate out of it? locked to quite tiny one as far as I can tell comparing to my other cams that push 16k bitrate >
I would expectr to push at least 2000 kB/s but getting only 200 now :/
Any hints?
Any hints?
I was referring to using the PTZ controls, not the curl commands to tell it to use different presets. in post #18 https://ipcamtalk.com/threads/annke-wz500-info.71482/post-792075
As for the baud rate. I'm not sure on that. Mine is ~180kB/s. Which i figured was because of it being a wireless device. None of mine are running as high as any of yours there.
Hello,
Have you already faced a message similar to "cannot be modified in patrol mode", when you try to add a position preset ?
It has been indeed inactivated (and was useless for me), I managed to remove the other positions (on the web interface).
The most annoying behavior is that I still don't get any notification anymore on my mobile. At some point it was managed by my domotic system (activate or inactivate the detection), but suddenly it doesn't work.
A part from that, it's a great camera to dispel doubt when some other camera triggers. There is now a WZ520 at a decent price too. Curious if the base is the same and could also be driven by url commands.
