I think it was. I returned and went for the English version.because it was an earlier firmware. Just update to the latest unless your camera is a china cam.
Sent from my SM-G955U using Tapatalk
China cams can be English...you want a world/international or us regionI think it was. I returned and went for the English version.
I'll have to check. I'm not sure. The firmware was the latest but as you.mentioned my first was the Chinese version.China cams can be English...you want a world/international or us region
It's too bad there isn't an equivalent replacement of this ANNKE. Since it was discontinued it's been hard to find good indoor cameras in the $40-60 range.
Hello,
Since the Annke Cube camera is not available any more, can anyone please recommend a good budget alternative?
Many thanks
Look one post up!
Sent from my iPhone using Tapatalk Pro
You were pointed to it.Already seen that. Thank you.
I was looking for a general consensus with regards to recommendations for a successor to the Annke Cube.
It's not clear if this specific one has WiFi capability. From what I can see, the model K55s definitely has, however is a lot more pricey.
Given the above, I'm wondering if there's any other option?
Only K35S has WiFi.It's not clear if this specific one has WiFi capability. From what I can see, the model K55s definitely has, however is a lot more pricey.
If anyone needs these files since they're no longer available on HIK's website. See the link below. Luckily I still had them available on my PC from a while back.
HIK FIRMWARE IPCAMTALK.rar
Which versions are you looking for?anyone else still happen to have these firmware files?
Probably a shot in the dark and this is a big necro, but do you or anyone else still happen to have these firmware files? I have a lone cam that looks like i never upgraded fw on (or used for that matter) and can't find my old copies of the fw either.
thanks!
I have 5.4.0, 5.4.3, and 5.4.5
Mark
Sent from my iPad using Tapatalk Pro
There are some on the IPcamtalk downloads area :
DS-2CD1x10 ,2xx0, 2X14, 4xx0 - Updates
ipcamtalk.com
And a few more on the RU Hikvision ftp site :
ftp:/ftp.hikvision.ru/02.%202-line%20cameras/2.%20R2%20platform%20-%20DS-2CD2X22F-IS%20(2mpx)/
I was looking for 5.4.0. I think I've found it. the EU site still has 5.4.3 and 5.4.5. But I think I've found it in a retired section of the eu hikvision site.
Is there any compelling reason to upgrade past 5.4.5 170123 to either the newer 5.4.5 or 5.4.8? If I wanted to go to 5.4.8, should I upgrade to the newer 5.4.5 first?
thanks
Upgrade to 5.4.5 first just to be safe. I upgraded to 5.4.8 which fixed an issue with setting streams from HD to SD on the app would cause a hard change on the device basically resetting all image settings making it only 720p or pixelated
Hello,Upgrade to 5.4.5 first just to be safe. I upgraded to 5.4.8 which fixed an issue with setting streams from HD to SD on the app would cause a hard change on the device basically resetting all image settings making it only 720p or pixelated
