Annke Firmware to Hikvision Firmware: HOW TO
WTF?!
Why was my post deleted? I provided a link to the description of how to return to the original firmware. I have verified myself that this method is effective!
I checked it out and assessed it as a SPAM link - that's why.
how to back annke firmware :D
"he type of upgrade file mismatches. "
Installed IPCE_R_E8_EN_STD_5.7.12_220819 (no human detect)
Want to back V5.5.120_210705 (got human detect)
Just FYI:
I've updated both my Annke C500 (I51DL) and my AC500 (I51EL) to Hikvision firmware IPCE_E10_EN_STD_5.7.11_230308 via the webinterface.
Both work fine, and there seem to be some new settings in the camera.
Unfortunately they still require the plugin to be installed for the liveview.
Edit:
Found a newer version, V5.7.12_SP1 E10 (2023-06-14).
Which also seems to be working fine.
Reactions: J_T
You won’t get any advantages from the hikvision firmware, but there are some disadvantages. loss of definition of person, car, resolution will drop to 4mp.
going back to the ANNKE firmware will not be so easy.
on new cameras there are no problems with switching to 4mp, after the firmware there will still be 5 megapixels, but the resolution may change, it won’t be “3k”
I know about the disadvantages.
I use Frigate as an NVR, so loss of those functions is not a problem for me.
Resolution is indeed 4MP now.
Hello.
How to restore annke firmware?
Yes, I found this.
There is one problem, the C500 does not have such a connector :D
I will completely disassemble it, are you sure there is such a communication port not only on the more expensive models?
Of course you have the firmware.
but you would also need such a cable.
  • Screenshot 2023-10-30 at 17-49-03 1019.08HUF Original 1m Cp2102 Usb To Uart Ttl Cable Module 4...png
Hello, I would like some help
looking for firmware annke N48PAW V4.71.000 build C-R-K9B2-00
Thanks.
what I know so far is the kina DS-7608N-E1/8P-V3
but I can't find anything for this..
Why is it so hard to restore the original Annke firmware for some people or cameras?
To test, I just flashed it back via the web interface on my C500 and it works fine again as an Annke camera with 3K instead of the lower Hikvision resolution.
interesting point about Annke cameras, they are all 5 mp, where does 5 mp come from if hikvision all cameras have 4 mp
