Amcrest IP4M-1041B - getting substream and pan/tilt to work
Thank you @Flintstone61 - it is helpful to see that it is working for your GetSystemDateAndTime. When I set to 80, it just redirects to 443 anyway. Port 80 or port 554 didn't help - I tried with the PTZ ports as well. I also tried pretty much all the combinations of the drop down and ports, but I'm open to new ideas... Any time I do Find/Inspect it doesn't seem to properly identify the camera, and it resets my streams (I needed to manually set my Sub to /cam/realmonitor?channel=1&subtype=1 to get the substream to work).
403 means Forbidden, so perhaps it is a permissions problem? Initially I did have this camera attached to a restricted user that did not have PTZ. Now it is attached to a user with full permissions -
The only other web cam option I can find for ONVIF is this one - I've tried both Enable and Disabled, neither works.
The other thing I thought might help was Information -> Log, but it does not seem to log any of the 403 attempts to get to ONVIF.
@CarlosBarletta any ideas on how to debug this? How to get more logs? Is there perhaps a firmware update as well?
Thanks.
does the PTZ controls work from the Amcrest web gui? Oh nevermind i reread your OP.
send a screen shot of the network/ tcp/ip stuff. like port 3777, port 554, blah blah blah....something is set wrong.
Here are the ports. Defaults, I think. HTTPS is enabled, and it made me create a cert. In Network, I also turned off UPnP if it was on - I forget if it was.
@Flintstone61 you've solved it!
Once I turned off HTTPS in Amcrest web setup, Find/Inspect found the camera, and discovery succeeded all calls. I did need to uncheck 'use another ip/port' on the PTZ tab, as Find didn't automatically fix that for me (I had turned it on at some point). Here's what my PTZ and Video look like now -
And in Setup in the camera web portal -
Reactions: Flintstone61
Yeah I 've run into that once before. I just undid https that i had just turned on with a new Amcrest setup when the varifocal cam wouldn't respond.
Reactions: Darkhog
This still appears to be a problem. I'm running BI 5, latest Amcrest firmware, IP4M-1041W cameras. PTZ will not function from BI with HTTPS enabled on the cameras.
It's been over a year for me and just got this Amcrest IP4M-1051 working with BI. Disable Audio on the Blue Iris camera settings, then try the Amcrest settings, then use the Amcrest and the IP4M-1051.
Then after the camera image showed up in BI, I logged into the cameras web address and changed the Audio Codec to G711A. Went back to the Blue Iris Camera Settings and re-abled Audio.
Finally Worked on my system....it was the audio hanging it up.
...Also for PTZ, I used the Amcrest/Dahua ...and it worked first time.
Amcrest IP4M-1041B
Reactions: TonyR
