alastairstevenson
Staff member
Which password is that?the default password doesn't work
There are several, eg
12345
123456
123456789abc
You probably didn't reset it.I already reset the camera, but the default password doesn't work
user: adminWhich password is that?
12345
123456
123456789abc
no, I already reset the camera, but the default password doesn't work
For configurationFile2.zip two passwords were found in the file login admin password 12345 1111111q
For configurationFile3.zip two passwords were found in the file login admin password 12345 1111111q
What device is that from and how did you extract the file?the config file has been attached
i went in the maintainance menu AND EPORTED THE CONFIG FILE FROM THE NVR . I KNOW THE PARTTEN NOT THE PASSWORDWhat device is that from and how did you extract the file?
It's not in the same format that's the subject of this thread.
No it does not haveDoes the NVR have PoE ports?
Do you have a Hikvision camera with firmware older than 3.4.5 ?
I have cameras that are all v5.5 and above
Can you decode this for me please? thank youDoes the NVR have PoE ports?
Yes, I can!Can you decode this for me please?
| DS-2CD1043G0-I | Active | 192.168.254.15 | 8000 | 8443 | V5.5.88build 200317 | | 80 | DS-2CD1043G0-I20200610AAWRE50118227 | 255.255.255.0 | 10-12-fb-0c-ef-aa | 0 | V7.3 build 190731 | 2021-07-16 04:41:36 | :: | :: | 64 | Yes | Yes | Yes | OFF | Yes | OFF |
That's a 'Password reset request export file' that requires a response from a Hikvision private support system, unfortunately this would have to be from Hikvision staff with system access.the config file has been attached
But the product information suggests the camera should have a reset button next to the SD card slot.
If so - press the reset button, power on the camera, wait 30 seconds and the camera should be reset to defaults, 'inactive' so that you can 'activate' it with your own choice of password.
Use SADP to show the status and activate.
That's a pity.it doesn't have a sd slot
The file decrypted OK.
And the password for admin on the HIKVISION DS-2CD2132F-I - 561429512 is
360sytems
Certainly! And well done for doing the extract.Hi is it possible to let me know the password for this configuration file?
Yes, Carlos, no problem.
The admin password for the Back_Shed HIKVISION DS-2CD3345-I - 629946268 camera is
Admin1234
The password for admin on the HIKVISION DS-2CD2332-I - 50829483 "Back - Patio" camera is
Belkin6647!
Hopefully that will be the same as that of the NVR.
