alastairstevenson
Staff member
			No, that's not needed.Does the NVR and camera's need an internet connection to talk to SADP
Just a local network connection for both devices.
If using a switch as opposed to NVR PoE ports - the camera would need to be powered, either by external 12v or a PoE switch.
If the NVR was on a static IP address - nothing would change in terms of the NVR and the cameras connected to its PoE ports. They would still connect OK on the NVR PoE ports.The whole issue was they changed modems and ISP, and so the entire network went down it was reconfigured for their uber eats tablet and Point of Sale machine and printers except for the NVR and camera's. Since they couldn't connect to them.
To regain access, all that's needed is to change the PC IP address to be in the range used previously, log in to the NVR web GUI, and change the NVR IP address to suit the new network.
Job done.
If (should be unlikely) the NVR has DHCP enabled, it will already have been given an IP address on the new network, which SADP will show.
In which case the NVR can be accessed at that IP address.
Can you confirm that the cameras were connected to NVR PoE ports?
