alastairstevenson
Staff member
Let's hope so!can you please help to recover my Nvr admin password?
The admin password for the MAIN DECK HIKVISION DS-2CD2232-I5 - 482311325 camera is
12345
Thank you, this camera user and password I can find using a hexedit, but do you have any idea how to extract/find the admin password for the Nvr? The guy who installed it is gone and I need to add new ip cameras, without admin it is useless unfortunatelyLet's hope so!
12345
The 'trojan horse method' of finding an NVR admin password depends on the fact that apart from the later versions of NVR firmware, it was the NVR admin password that was used to 'activate' an 'inactive' camera when first plugged in to an NVR PoE port.do you have any idea how to extract/find the admin password for the Nvr
Thank you so much! This is what I was trying to do right now.The 'trojan horse method' of finding an NVR admin password depends on the fact that apart from the later versions of NVR firmware, it was the NVR admin password that was used to 'activate' an 'inactive' camera when first plugged in to an NVR PoE port.
And then the backdoor vulnerability of camera firmware of 5.4.0 or earlier could be used to extract the camera configuration file to reveal the camera password. Which was usually also the NVR admin password.
Earlier firmware than 5.3.0 does not have the active/inactive facility, it still uses the old default passwords of 12345 and 123456789abc which the NVR will try first when connecting the camera.
That may explain why the '12345' password was extracted. You may have to update the camera firmware a little for this method to work.
So - did you follow these steps :
Reset to default settings (ie 'inactive') a camera with firmware between 5.3.0 and 5.4.0 when not connected to the NVR.
Connect the camera to the NVR PoE port and wait for it to be 'activated' by the NVR and go online.
Extract the configuration file using the backdoor vulnerability.
Decrypt and decode the file to reveal the admin password.
Could you please decode these files.Let's hope so!
12345
Not with this method - it relies on the NVR 'Activating' the camera with what's usually the NVR password.My question is: Can I force the NVR's password onto the camera I have (V 5.4.0) WITHOUT resetting the camera to factory defaults?
I ask because I'm using iVMS4200 and I set it up a LONG time ago and wouldn't remember the millions of settings I'd have to fiddle with forever to get it back to what I have now. I have 4 cameras and have been working well for 11 years without me changing anything.
When you reset the camera to default settings, did it show as 'Inactive' in SADP or via the browser? I suspect not. That's important for this method.So the NVR did NOT pass its password to my deactivated (restored to default) camera, despite showing the video feed. Any thing I'm missing?
Well, that's a good helpful result, at a reasonable price.I just did give in and paid $20 online to A1 Security Cameras (an LTS dealer) who gave me a Secure Code to reset the password. And it worked! So I'm now in!
you can do this yourself using the form on the website.Hi i am trying to recover admin password for truvision nvr
This is rebranded hikvision and can see it in sadp tool
i have followed instructions and connected a hikvision camera with firmware v5.3 to nvr
i now have the config file could you please extract password for nvr please
much appreciated
admin Pass4111dont know if im reading it wrong or it just isnt working
but password i put in doesnt seem to be working on nvr
could someone double check what password for nvr would be
thanks
