Honeywell security products are some of the best on the market! The only products I can't speak for as I haven't used them yet is their video confirmation cameras. The Vista series panels are tried and true and the backbone of the security industry. I still run a Vista 20P that I've had since 2004.
The Vista 21ip is okay. Understand that ip based monitoring is dependent on your network which is not 100% reliable. I'd you where to do ip with cellular backup that would be much better than just ip. I haven't used alarm grid. I've used Alarm Relay and now I'm a dealer for Rapid Response.
The dealer is the authorized seller of the services. For instance if you wanted to use alarm.com, you yourself could not go straight to alarm.com, they would refer you to an authorized alarm.com dealer.
