[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.10.73+ (zhangtao12@Cpl-Frt-BSP) (gcc ?? 4.8.2 20130902 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2013.09) ) #2 PREEMPT Wed Oct 28 13:55:47 CST 2015
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Ambarella S2L (Flattened Device Tree), model: Ambarella S2LM Kiwi Board
[ 0.000000] dev type:0x0
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] Ambarella: AHB = 0xe0000000[0xe0000000],0x01000000 0
[ 0.000000] Ambarella: APB = 0xe8000000[0xe8000000],0x01000000 0
[ 0.000000] Ambarella: PPM = 0x00000000[0xdfe00000],0x00200000 9
[ 0.000000] Ambarella: AXI = 0xf0000000[0xf0000000],0x00030000 0
[ 0.000000] Ambarella: DRAMC = 0xdffe0000[0xef000000],0x00020000 0
[ 0.000000] Ambarella: DBGBUS = 0xec000000[0xec000000],0x00200000 0
[ 0.000000] Ambarella: DBGFMEM = 0xee000000[0xee000000],0x01000000 0
[ 0.000000] Ambarella: IAVMEM = 0x06800000[ ],0x09800000
[ 0.000000] On node 0 totalpages: 26112
[ 0.000000] free_area_init_node: node 0, pgdat 807aeb80, node_mem_map 807de000
[ 0.000000] Normal zone: 204 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 26112 pages, LIFO batch:7
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 25908
[ 0.000000] Kernel command line: console=ttyS0 KRN_PRT=pri
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 102MB = 102MB total
[ 0.000000] Memory: 95392k/95392k available, 9056k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0x86800000 - 0xff000000 (1928 MB)
[ 0.000000] lowmem : 0x80000000 - 0x86600000 ( 102 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x804fb2cc (5069 kB)
[ 0.000000] .init : 0x804fc000 - 0x8077b71c (2558 kB)
[ 0.000000] .data : 0x8077c000 - 0x807b69a0 ( 235 kB)
[ 0.000000] .bss : 0x807b69a0 - 0x807d94a8 ( 139 kB)
[ 0.000000] NR_IRQS:240
[ 0.000000] sched_clock: 32 bits at 54MHz, resolution 18ns, wraps every 79536ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttyS0] enabled
[ 0.230913] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.292605] pid_max: default: 32768 minimum: 301
[ 1.755438] Card authentication succeeded
[ 1.759501] Mount-cache hash table entries: 512
[ 1.766205] CPU: Testing write buffer coherency: ok
[ 1.771378] Setting up static identity map for 0x803c20c0 - 0x803c2118
[ 1.781377] devtmpfs: initialized
[ 1.785813] pinctrl core: initialized pinctrl subsystem
[ 1.791346] NET: Registered protocol family 16
[ 1.796502] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 1.803862] L310 cache controller enabled
[ 1.807863] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
[ 1.817232] ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
[ 1.825232] ambarella-gpio gpio.0: Ambarella GPIO driver registered
[ 1.833031] read dev-tree[misc_ctrl_pin] pro [rst_time] error!
[ 1.833042] read dev-tree[misc_ctrl_pin] pro [rst_delay] error!
[ 1.835530] bio: create slab <bio-0> at 0
[ 1.840626] ambarella-dma e0005000.dma: Ambarella DMA Engine
[ 1.848178] ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed!
[ 1.855243] Advanced Linux Sound Architecture Driver Initialized.
[ 1.861996] Switching to clocksource ambarella-cs-timer
[ 1.873839] ambarella-sd e0002000.sdmmc0: Slot0 use bounce buffer[0x85f20000<->0x06120000]
[ 1.882129] ambarella-sd e0002000.sdmmc0: Slot0 req_size=0x00020000, segs=32, seg_size=0x00020000
[ 1.891000] ambarella-sd e0002000.sdmmc0: Slot0 use ADMA
[ 1.967319] ambarella-sd e0002000.sdmmc0: 1 slots @ 24000000Hz
[ 1.973328] NET: Registered protocol family 2
[ 1.981678] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 1.988784] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 1.995155] TCP: Hash tables configured (established 1024 bind 1024)
[ 2.001588] TCP: reno registered
[ 2.004841] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 2.010708] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 2.017141] NET: Registered protocol family 1
[ 2.021856] RPC: Registered named UNIX socket transport module.
[ 2.027828] RPC: Registered udp transport module.
[ 2.032510] RPC: Registered tcp transport module.
[ 2.037190] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.237824] msgmni has been set to 186
[ 2.245958] NET: Registered protocol family 38
[ 2.250569] io scheduler noop registered
[ 2.254506] io scheduler deadline registered
[ 2.258833] io scheduler cfq registered (default)
[ 2.264006] ambarella-fb ambarella-fb.0: ambfb_probe: use prealloc.
[ 2.270585] ambarella-fb ambarella-fb.0: probe p[320x240] v[320x480] c[16] b[0] l[1280] @ [0x00100000:0x00100000]!
[ 2.281334] e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
[ 2.288601] ambarella-uart e0032000.uart: Serial[1] use txdma
[ 2.294377] ambarella-uart e0032000.uart: Serial[1] use rxdma
[ 2.300171] e0032000.uart: ttyS1 at MMIO 0xe0032000 (irq = 25) is a ambuart
[ 2.308001] brd: module loaded
[ 2.313632] loop: module loaded
[ 2.320432] ambarella-nand e0001000.nand: in ecc-[1]bit mode
[ 2.326075] ambarella_nand: Use On Flash BBT
[ 2.330454] NAND device: Manufacturer ID: 0x98, Chip ID: 0xf1 (Toshiba NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64
[ 2.342697] Bad block table found at page 65472, version 0x01
[ 2.348625] Bad block table found at page 65408, version 0x01
[ 2.354539] nand_read_bbt: bad block at 0x000006000000
[ 2.359780] 16 ofpart partitions found on MTD device amba_nand
[ 2.365590] Creating 16 MTD partitions on "amba_nand":
[ 2.370732] 0x000000000000-0x000000020000 : "bst"
[ 2.376153] 0x000000020000-0x000000120000 : "bld"
[ 2.381582] 0x000000120000-0x000000200000 : "ptb"
[ 2.386877] 0x000000200000-0x000000280000 : "env"
[ 2.392265] 0x000000280000-0x000000380000 : "sysflg"
[ 2.397933] 0x000000380000-0x000000400000 : "param"
[ 2.403554] 0x000000400000-0x000000500000 : "dpt"
[ 2.412038] 0x000000500000-0x000000f00000 : "rcvy"
[ 2.417584] 0x000000f00000-0x000001700000 : "krn_pri"
[ 2.423352] 0x000001700000-0x000001f00000 : "krn_sec"
[ 2.429194] 0x000001f00000-0x000004100000 : "app_pri"
[ 2.434959] 0x000004100000-0x000006300000 : "app_sec"
[ 2.440780] 0x000006300000-0x000006900000 : "cfg_pri"
[ 2.446500] 0x000006900000-0x000006f00000 : "cfg_sec"
[ 2.452287] 0x000006f00000-0x000007700000 : "dbg"
[ 2.457751] 0x000007700000-0x000007f00000 : "syslog"
[ 2.464054] ambarella-spi e0020000.spi: Ambarella spi controller 0 created.
[ 2.471265] tun: Universal TUN/TAP device driver, 1.6
[ 2.476295] tun: (C) 1999-2004 Max Krasnyansky <
[email protected]>
[ 2.537233] libphy: Ambarella MII Bus: probed
[ 2.543024] ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x001cc816!
[ 2.550355] ambarella-eth e000e000.ethernet: MAC Address[28:57:be:35:2a:26].
[ 2.557501] PPP generic driver version 2.4.2
[ 2.561937] PPP BSD Compression module registered
[ 2.566621] PPP Deflate Compression module registered
[ 2.571882] mousedev: PS/2 mouse device common for all mice
[ 5.577246] ambarella-i2c e8003000.i2c: No ACK from address 0xa2, 0:0!
[ 5.584093] ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0
[ 5.591776] pcf85163 is not exist.
[ 5.595158] i2c /dev entries driver
[ 5.599151] ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed.
[ 5.606451] Netfilter messages via NETLINK v0.30.
[ 5.611269] nf_conntrack version 0.5.0 (1490 buckets, 5960 max)
[ 5.617569] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.622907] TCP: cubic registered
[ 5.626245] NET: Registered protocol family 10
[ 5.631565] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.637001] sit: IPv6 over IPv4 tunneling driver
[ 5.642264] NET: Registered protocol family 17
[ 5.646750] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 5.654426] ThumbEE CPU extension supported.
[ 5.659871] ambarella-rtc e8015000.rtc: setting system clock to 2016-01-11 12:03:04 UTC (1452513784)
[ 5.669098] ALSA device list:
[ 5.672049] No soundcards found.
[ 5.678111] Freeing unused kernel memory: 2556K (804fc000 - 8077b000)
[ 6.270756] UBI: attaching mtd10 to ubi1
[ 6.365318] UBI: scanning is finished
[ 6.379770] UBI: attached mtd10 (name "app_pri", size 34 MiB) to ubi1
[ 6.386196] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 6.395679] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 6.402445] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 6.409316] UBI: good PEBs: 272, bad PEBs: 0, corrupted PEBs: 0
[ 6.415212] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 6.422336] UBI: max/mean erase counter: 4/2, WL threshold: 4096, image sequence number: 464094546
[ 6.431278] UBI: available PEBs: 0, total reserved PEBs: 272, PEBs reserved for bad PEB handling: 10
[ 6.440407] UBI: background thread "ubi_bgt1d" started, PID 268
[ 6.462025] UBIFS: background thread "ubifs_bgt1_0" started, PID 273
[ 6.489440] UBIFS: recovery needed
[ 6.561389] UBIFS: recovery completed
[ 6.565240] UBIFS: mounted UBI device 1, volume 0, name "app_pri"
[ 6.571392] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 6.580520] UBIFS: FS size: 31490048 bytes (30 MiB, 248 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs)
[ 6.590158] UBIFS: reserved for root: 1487352 bytes (1452 KiB)
[ 6.595973] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 4BB2DFB7-7C1E-4DC5-B8EC-713E7D82685F, small LPT model
[ 6.619441] UBI: attaching mtd12 to ubi3
[ 6.639462] UBI: scanning is finished
[ 6.653337] UBI: attached mtd12 (name "cfg_pri", size 6 MiB) to ubi3
[ 6.662401] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 6.669254] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 6.675932] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 6.682803] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
[ 6.688625] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 6.695734] UBI: max/mean erase counter: 7/4, WL threshold: 4096, image sequence number: 588181012
[ 6.704674] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
[ 6.713716] UBI: background thread "ubi_bgt3d" started, PID 277
[ 6.735176] UBIFS: background thread "ubifs_bgt3_0" started, PID 282
[ 6.762516] UBIFS: recovery needed
[ 6.837243] probe_rst_pin exceed
[ 6.859690] UBIFS: recovery completed
[ 6.863502] UBIFS: mounted UBI device 3, volume 0, name "cfg_pri"
[ 6.869647] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 6.878772] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 6.888060] UBIFS: reserved for root: 143937 bytes (140 KiB)
[ 6.893703] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 73A1B907-A4D4-4144-A07F-10FB8AA0F16E, small LPT model
[ 6.959012] UBI: attaching mtd13 to ubi4
[ 6.979694] UBI: scanning is finished
[ 6.993877] UBI: attached mtd13 (name "cfg_sec", size 6 MiB) to ubi4
[ 7.002933] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 7.009776] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 7.016453] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 7.023323] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
[ 7.029142] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 7.036252] UBI: max/mean erase counter: 6/3, WL threshold: 4096, image sequence number: 497676451
[ 7.045190] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
[ 7.054229] UBI: background thread "ubi_bgt4d" started, PID 287
[ 7.075738] UBIFS: background thread "ubifs_bgt4_0" started, PID 292
[ 7.103980] UBIFS: recovery needed
[ 7.186464] UBIFS: recovery completed
[ 7.190354] UBIFS: mounted UBI device 4, volume 0, name "cfg_sec"
[ 7.196470] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 7.205601] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 7.214890] UBIFS: reserved for root: 143937 bytes (140 KiB)
[ 7.220543] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 92C5416F-ED41-42AE-8529-ACE6C50861BF, small LPT model
[ 7.314827] net eth0: adv: sym 1, asym: 1
[ 7.319088] net eth0: lp: sym: 0, asym: 0
[ 7.323149] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.006011] dsp: module license 'Proprietary' taints kernel.
[ 9.013877] Disabling lock debugging due to kernel taint
[ 9.041357] img: IMG KERN VIRT: WR [0x86af5000, 184 KB], RD [0x85f70000, 36 KB].
[ 9.153156] amba_debug_init 248:248.
[ 9.241030] base module init.
[ 9.255789] [ kernel version: svn-149524 ]
[ 9.264732] mmc0 power register success!
[ 9.268760] mmc1 power register success!
[ 9.272665] request sd[mmc1] power ctrl pin error!
[ 9.277456] usb0 power register success!
[ 9.297028] usbcore: registered new interface driver usbfs
[ 9.307510] net eth0: lp: sym: 0, asym: 0
[ 9.311511] libphy: e000e000.etherne:00 - Link is Up - 100/Full
[ 9.320664] usbcore: registered new interface driver hub
[ 9.328253] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.335906] usbcore: registered new device driver usb
[ 9.346728] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 9.355737] ambarella-ehci e0018000.ehci: EHCI Host Controller
[ 9.361713] ambarella-ehci e0018000.ehci: new USB bus registered, assigned bus number 1
[ 9.369929] ambarella-ehci e0018000.ehci: irq 39, io mem 0xe0018000
[ 9.387265] ambarella-ehci e0018000.ehci: USB 2.0 started, EHCI 1.00
[ 9.393687] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.400482] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.407693] usb usb1: Product: EHCI Host Controller
[ 9.412549] usb usb1: Manufacturer: Linux 3.10.73+ ehci_hcd
[ 9.418109] usb usb1: SerialNumber: AmbUSB
[ 9.424879] hub 1-0:1.0: USB hub found
[ 9.433944] hub 1-0:1.0: 2 ports detected
[ 11.477689] RTL871X: module init start
[ 11.481433] RTL871X: rtl8188eu v4.3.0.4_11485.20140519
[ 11.486548] RTL871X: build time: Nov 3 2015 15:11:55
[ 11.495170] usbcore: registered new interface driver rtl8188eu
[ 11.503183] RTL871X: module init ret=0
[ 11.514334] mmc0: SD Status: Invalid Allocation Unit size.
[ 11.523617] mmc0: new SDXC card at address aaaa
[ 11.531840] mmcblk0: mmc0:aaaa SL64G 59.4 GiB
[ 11.557154] mmcblk0: p1 p2
[ 20.579604] event(demo_event) init callback null!
[ 20.579623] initialized demo_event
[ 20.583023] init pin 96 for wps pbc function
[ 20.589520] initialized wps_event
[ 20.592826] event(alarm) init callback null!
[ 20.592832] initialized alarm
[ 23.657283] ambarella-i2c e8003000.i2c: No ACK from address 0x36, 0:0!
[ 23.663798] codec 4954
[ 23.666375] snd_soc_card_amba sound.1: ASoC: CODEC (null) not registered
[ 23.673117] snd_soc_card_amba sound.1: snd_soc_register_card failed (-517)
[ 23.680007] platform sound.1: Driver snd_soc_card_amba requests probe deferral
[ 23.691443] ak4954 i2c probe
[ 23.694605] ak4954-codec 0-0012: AK4954 Audio Codec 0.1
[ 23.703557] AK4954 probe
[ 23.707433] ak4954 module init
[ 29.809527] <ak4954_set_in_volum>set device_id success!
[ 29.814740] AK4954:set input volum 50
[ 29.877292] audio codec's ID = 0
[ 29.907335] SYSCLK:SO[24007680]
[ 29.935139] audio codec AK4954 initialized!
[ 29.948987] snd_soc_card_amba sound.1: ak4954-hifi <-> e001a000.i2s mapping ok
[ 29.956292] snd_soc_card_amba sound.1: ASoC: no sink widget found for LIN2
[ 29.977231] snd_soc_card_amba sound.1: ASoC: Failed to add route Mic internal -> direct -> LIN2
[ 29.985904] snd_soc_card_amba sound.1: ASoC: no sink widget found for RIN2
[ 30.007231] snd_soc_card_amba sound.1: ASoC: Failed to add route Mic external -> direct -> RIN2
[ 30.015908] snd_soc_card_amba sound.1: ASoC: no sink widget found for LIN3
[ 30.037225] snd_soc_card_amba sound.1: ASoC: Failed to add route Line In -> direct -> LIN3
[ 30.045463] snd_soc_card_amba sound.1: ASoC: no sink widget found for RIN3
[ 30.067224] snd_soc_card_amba sound.1: ASoC: Failed to add route Line In -> direct -> RIN3
[ 30.075463] snd_soc_card_amba sound.1: ASoC: no source widget found for SPKLO
[ 30.097224] snd_soc_card_amba sound.1: ASoC: Failed to add route SPKLO -> direct -> Line Out
[ 30.105636] snd_soc_card_amba sound.1: ASoC: no source widget found for SPKLO
[ 30.134093] snd_soc_card_amba sound.1: ASoC: Failed to add route SPKLO -> direct -> Line Out
[ 30.142786] snd_soc_card_amba sound.1: ASoC: no source widget found for HPR
[ 30.150100] snd_soc_card_amba sound.1: ASoC: Failed to add route HPR -> direct -> HP Jack
[ 30.158434] snd_soc_card_amba sound.1: ASoC: no source widget found for HPL
[ 30.165439] snd_soc_card_amba sound.1: ASoC: Failed to add route HPL -> direct -> HP Jack
[ 30.173854] snd_soc_card_amba sound.1: ASoC: no source widget found for SPKLO
[ 30.181080] snd_soc_card_amba sound.1: ASoC: Failed to add route SPKLO -> direct -> Speaker
[ 30.189518] snd_soc_card_amba sound.1: ASoC: no source widget found for SPKLO
[ 30.196707] snd_soc_card_amba sound.1: ASoC: Failed to add route SPKLO -> direct -> Speaker
[ 30.314841] SYSCLK:VOUT[27000000]
[ 30.318188] ambarella_vout_clk_set_rate: rate = 27000000
[ 37.321714] set audio rates 8000Hz
[ 37.348396] set audio rates 8000Hz
[ 37.596024] AK4954:set input volum 50
[ 42.327447] net eth0: lp: sym: 0, asym: 0
[ 42.331449] libphy: e000e000.etherne:00 - Link is Down
[ 43.976739] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 44.045098] FAT-fs (mmcblk0p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 44.337459] net eth0: lp: sym: 0, asym: 0
[ 44.341461] libphy: e000e000.etherne:00 - Link is Up - 100/Full
[ 44.811695] ambarella_vout_clk_set_rate: rate = 27000000
[ 45.698316] ambarella_vout_clk_set_rate: rate = 27000000
[ 46.342840] event_notify_receive_skb: event id 3, pid is 526
[ 46.352803] event 3 bind pid 526
