Thank you for that info. From what I understand, I need three runs to enable redundancy. If I use 6 strand wire, can I use a connector in the center location to connect the wires from Bldg3 to Bldg1, and in that way only run 2 wires? Will I lose a lot of speed if I use a connector instead of one long run? The total distance would be 435 feet.
Bldg3 ==>   180 feet (10 feet outside)  ==>         Bldg2    255 feet (30 feet outside)  ==>    Bldg3
I'm a stone cold newbie when it comes to fiber, so I may be way off base. I thought multimode was faster than single mode and OM4 would allow for greater speed if  faster switches were put in later? I am using 3 Cisco switches with 10G fiber uplinks so I only need 10G for now. Singlemode looks to be cheaper for the fiber and the transceivers for the Cisco switches are only slightly more expensive if I buy them used. I understand Singlemode works for longer distances, but should I go with it here? (Again I'm just trying to understand, I want the best solution for now and long term. When someone comes after me, I want them to say we did it right!) So go with Singlemode or multimode?
Also, and I'm probably asking a very dumb question (or even another dumb question) - but here it is. Is it all worth considering buying bulk fiber and terminating the ends ourselves?
I am volunteering my work on this job and working on a tight budget,  so I cannot that you enough for your knowledge and time. I am reading on different sites, but it's hard to get information on specific situations.
