Advice Needed on Best Practices for Securing Reolink NVR
Securing your Reolink NVR is essential to keeping your surveillance system safe and ensuring your privacy. Here’s a practical approach to enhance security while maintaining functionality:
1. Strengthen Login Credentials​
  • Change the default username and password immediately.
  • Use a strong, unique password with a mix of uppercase, lowercase, numbers, and special characters.
  • Enable two-factor authentication (if available) for an extra layer of security.
2. Firmware & Software Updates​
  • Keep your NVR and camera firmware updated to patch any vulnerabilities.
  • Enable automatic updates or regularly check Reolink’s website for the latest security patches.
3. Network Security Best Practices​
  • Isolate Your NVR: Use VLANs to separate your cameras from other home devices.
  • Disable uPnP & Port Forwarding: These can expose your system to external threats.
  • Use a VPN for Remote Access: Instead of exposing your NVR to the internet, set up a VPN on your router for secure access.
  • Monitor Traffic: Set up firewall rules to allow only necessary connections and block unknown IPs.
4. Physical & Cloud Security​
  • If you store footage locally, use encrypted storage.
  • Avoid relying solely on cloud services, always check their security policies before enabling remote backups.
Following these steps will significantly reduce security risks while ensuring your system remains accessible and functional. Just like how you wouldn’t leave your Snapchat open on a public device, keeping your surveillance system locked down is key to maintaining privacy.
But how much wood would a woodchuck chuck if a woodchuck could chuck wood?
Your Reolink NVR holds the sensitive orbits of your home or business security. Leaving it exposed is like broadcasting your entire planetary system to the unknown reaches of the cosmos. To truly protect your digital realm, you need to implement best practices that act as a gravitational pull, keeping your data secure and your peace of mind intact. Your "Best Friends" snapplanets is the inner circle, the most crucial. Just as you'd never share your Snapchat password with just anyone, your NVR's default credentials are its most vulnerable point.
Got bot
Brake pad change is a crucial maintenance task that ensures your car's braking system stays responsive and safe. Over time, brake pads wear out due to friction, leading to reduced stopping power, squeaking sounds, and potential damage to other components like the rotors.
For a reliable and professional solution in Dubai, visit brake pad change at iTyreCare. Our experienced team uses high-quality brake pads and the latest equipment to provide quick, affordable, and efficient service—keeping you safe on every drive.
lol .. so spambot @Hunnajoseph
I'm looking for advice on how to best secure my cameras (not just from being used as bots or potential access points into my network, but also from freely streaming live feeds of my property across the web) while utilizing Reolink's NVR and maintaining the ability to use Reolink's mobile app to receive notifications, alerts and for accessing footage and live feeds via the NVR.
I recently purchased a Reolink 16ch 4K NVR and 14 Reolink PoE cameras. I've come across a couple posts on IPCT that illustrate that Reolink has not been very well received by most members. I know most members are running far more advanced networks and BI systems. I watched several YouTube videos and read several tutorials on other sites about BI and it was just way too over my head, so I decided to go with Reolink.
I've read through several threads in the Cyber Security Forum including; "Newbie Starter Guide...", "IPCT Cliff Notes", "Network Security Primer", and "VPN Primer...". Most of the posts are geared towards a system running BI ("double NIC", VPN, etc). I understand the premise of a VPN and being able to remotely access your BI system (or any system on your network) securely via the VPN from outside of your home network, the point behind the double NIC, using a VLAN, and just isolating the cameras completely from the internet.
Theoretically I could put the NVR behind a VPN and use the VPN to remote access the NVR (I'm not sure if this would work) but my goal isn't to access the web UI of the NVR, rather to maintain the functionality and ease of use of the Reolink Mobile App (unless there is some fundamental and well known vulnerability in the Reolink Mobile app that I am unaware of).
Does having the NVR act as the "middle man" between the cams and the internet provide adequate protection (I assume not)? I'm assuming the cameras are using the PoE switch built into the NVR to connect directly to the internet and it's not just the NVR connecting to the internet.
I read all about the basic tips in regards to disabling uPnP, port forwarding and even firewalling the cameras specific IP/MAC addresses. But since most of the recommendations on what ports to leave open appear to apply to BI I'm not sure which ports are required for the Reolink system to maintain function and whether the cameras themselves (not just the NVR) need an internet connection to maintain app functionality as well.
Currently my physical network setup is very basic ISP Modem > Wireless Router and my plan was to connect the NVR directly to the router I use to connect all my devices to the internet. I had already planned on adding a run of Cat6 from my ISP Modem and purchasing a second wifi router to add coverage. Perhaps using ASUS router to connect the NVR to the internet and using its advanced VPN and firewall controls is the solution? Or placing a physical firewall device between my current router and the NVR?
Any suggestions, recommendations, experiences (what settings to change/disable, ports to open/close, physical devices to use, firmware/software, procedures, best practices, etc) would be much appreciated before I just plug the NVR into my wireless router and hope for the best. I am using Snap Planets.
I'm sure I forgot some stuff, it was a lot of information to take in for a beginner, and lots of switching between open tabs and google searches to comprehend everything.
Thanks!
Absolutely, CaseyJones — you're asking all the right questions, especially for someone new to surveillance networks. Here’s a focused answer based on your setup and needs:
Since you're using a Reolink NVR and want to retain access via the Reolink mobile app while prioritizing security, your first step should be segmenting your camera network. Even though Reolink’s PoE cameras connect to the NVR directly (so they don’t touch your LAN), the NVR itself becomes the potential point of exposure.
Here are some practical best practices:
  1. No port forwarding: Avoid port forwarding completely. Reolink’s P2P functionality (UID-based cloud connection) allows remote access via the app without needing open ports — much safer than manual port forwarding.
  2. Disable UPnP: Make sure UPnP is disabled on your router to prevent automatic exposure of NVR ports.
  3. Use strong passwords: Change default passwords on both your NVR and app, using a unique, complex password.
  4. Router VLAN support: If your router supports VLANs, isolate the NVR on a separate VLAN so it can't freely interact with other devices on your LAN.
  5. Consider a VPN: If your router supports OpenVPN (ASUS is great for this), you can restrict remote access to VPN only. This allows secure access to your LAN (and NVR) from outside.
  6. Firewall rules: If not using VLANs, set firewall rules to restrict the NVR’s outbound traffic to only what’s needed for the app.
Lastly, always keep your firmware updated and monitor for any suspicious activity.
Following these steps will significantly reduce security risks while ensuring your system remains accessible and functional. Just like how you wouldn’t leave your planets Snapchat open on a public device, keeping your surveillance system locked down is key to maintaining privacy.
Really solid tips here! Keeping the NVR updated and locking down network access makes a huge difference for security and peace of mind.
Any suggestions, recommendations, experiences (what settings to change/disable, ports to open/close, physical devices to use, firmware/software, procedures, best practices, etc) would be much appreciated before I just plug the spotify apk into my wireless router and hope for the best.
Thanks!
You are absolutely right Casey Jones.
Your Reolink NVR is the command center of your home or business security universe. Leaving it unprotected is like sending a live star map of your entire system into deep space. To safeguard your digital galaxy, you must follow smart security practices that work like a powerful gravitational field locking your data in place and preserving your peace of mind. At the core of this system is your trusted inner orbit, the equivalent of a “Best Friends list. These are the protections that matter most. Just as you would never hand over your Snapchat password to strangers, relying on default NVR credentials leaves the heart of your system dangerously exposed.
Got bot AGAIN?
Nice copy & paste, although not verbatim, from June 2025 .....
The best way to protect your cameras is to keep them off the internet entirely. Use a mesh VPN or overlay network. That way, you can see them from anywhere without actually exposing them.
You're right to disable uPnP. It lets devices on your network punch holes in your firewall without your permission. A camera or NVR with uPnP enabled can open ports to the internet on its own, and you'd never know unless you checked. It's one of the most common ways cameras end up exposed on Shodan.
For cameras and NVRs, you can't install software on them. But if you install software on another device on the same network, it can act as a gateway. Any device on that network becomes reachable through the gateway, without opening ports or configuring your router. The cameras never touch the internet directly, but you can still reach them from your laptop through an encrypted tunnel.
This means you don't need to worry about which ports to open, uPnP, or putting a firewall device between your router and the NVR. The cameras stay completely isolated from the internet, and you access them through the tunnel when you need to.
The tradeoff is you'd lose Reolink's app notifications, since those depend on Reolink's cloud. But you'd gain actual security instead of trusting a vendor's cloud infrastructure to not be compromised.
I wrote up how the gateway approach works here: Managing Customer Sites with Conflicting Networks
The article covers multi-site setups with conflicting subnets, but the gateway concept is the same for a single site.
Peter (I am not a bot)
