5MP 2592 x 1944p Bullet best settings for 24/7 recording. Currently an hour of recording is about 5-6gb (I cut my clips in 30mins)
stevenjus
Joined
Dec 9, 2021
Messages
45
Reaction score
1
Location
us
[email protected]
Getting comfortable
Joined
Dec 4, 2015
Messages
317
Reaction score
300
Sorry. Is this advice for others to adhere to with your encoding settings. Or are you after guidance on correct optimal settings?
mat200
Joined
Jan 17, 2017
Messages
14,223
Reaction score
23,728
H264 vs H265 .. iirc also depends on the software you may use for alerts / triggers / AI - ML .. so want to check if there is a difference between those and what software you plan to use.
FPS .. many run at 15fps or even 8 fps to reduce load on system .. and storage space ..
Blue Iris .. also many like to set iFrame = fps ..
also try to maximize the capacity of your HDDs ..
stevenjus
Joined
Dec 9, 2021
Messages
45
Reaction score
1
Location
us
Just plain blu Iris with no AI
bigredfish
Joined
Sep 5, 2016
Messages
18,078
Reaction score
50,317
Location
Floriduh
Depends on what your goal is.
Without video its hard to say.
If the goal is to see how little HD space you can use, set it to 1024, 5fps, and VBR
Personally I aim for video quality, so 10240 bitrate, 30fps, CBR, H.264H, Std Codec (smart codec and h.265 OFF)
Top
