I’m currently using IVS on my 54IRs and spiders are causing them to trigger them as a human. I have sensitivity set at 4 and the minimum object size as about as large as I can for the FOV. What can I try next? Thanks
Make sure MD or SMD are not accidentally on. This can happen if not using IE or Edge not in IE mode. It may show off but really be on when checked in IE.
Do you have an SD card in the camera and confirm the IVS is triggering?
Yes, on the camera. I look at the spiders causing it to trigger, and I just can’t see how it triggers as a human. It wouldn’t be a problem except for the fact that I have Critical Alerts enabled for overnight and the false positives wake me up.
