I just exported a short clip using that option, mine worked fine.Under Web Server > Advanced > Encoder Profile (Steaming 0) Configure > Direct-to-wire where possible (H.264)
View attachment Cam2.20251026_090000.mp4
Yes, I discovered the same thing. Rolled back to .95 and everything was fine.Direct to wire streaming seems to be broken after the latest update (5.9.9.96). Anyone else seeing this issue?
It was discussed very briefly a few posts back. I had the same experience.I set the direct to wire option and UI3 will not display the main stream when I solo any of my cameras, when I clear the direct to wire option the main stream is again working when I solo any of the cameras. I have never used this setting, not sure what reason I would have to use this option.
Changelog: highlights are mine
[5.9.9.92] – 2025-10-13
Added
• Usability updates for the Calendar window; standard OK/Cancel, fix for Esc and Shift range selection
• Timeline zoom in/out retains the time focus position within the window; zooming with the mouse wheel moves the time focus to the point beneath the cursor
• The status bar background color now reflects important states: errors, warnings, alerts; cleared by opening the status window
I agree, was fine with just the little yellow triangle. Hopefully this will be an option in 6.0.RE: • The status bar background color now reflects important states: errors, warnings, alerts; cleared by opening the status window
Anyone found a way to turn this off? It is very distracting to have the big Red or Yellow bar, just because a camera dropped off momentarily or such. I have BI constantly running on a monitor at my workstation and it is distraction to have it catch my eye. And then I have to stop what I am working on, find the mouse for that system, and go in and open status window to get it to go back to normal. The color of the pie chart upper left is sufficient for my needs.
.97 won't install on my test system, it fails.I just updated from 5.5.1.6 to latest (5.9.9.97). Everything seemed to be okay, but then I started noticing some issues:
Reverted back to 5.5.1.6 (by re-running the old 5.5.1.6 update) and everything works as before. One caveat is that the downgrade somehow messed up the motion sensor settings, but I reimported the camera from a the original version and it was restored.
- MQTT notification seems to be broken. Clicking the "Test" button instantly crashes the application.
- Watchdog notifications to send MQTT notifications on signal loss/restoration seem to have been "lost" in the upgrade.
- After I manually re-enabled them, I noticed that BI publishes a message when the signal is lost but not when it's restored.
Anyone else seeing any of these issues?
Thanks.
You need to update your runtime version:
Thank you. Will try that over the weekend and report if that fixes the issue.You need to update your runtime version:
Latest supported Visual C++ Redistributable downloads
This article provides download links for the latest Visual C++ Redistributable packages.learn.microsoft.com
6.0.0 is nigh!!!!!!!!This will be the last release version of 5.x. The next update offered from this version will be a 6.x release (64 bit only).
