Im using zerotier and BI App on iphone on .2.3 and my webserver seems to be working.....lemme turn off wifi....Ok ....yeah it's working on 5G cellular as well.
lemme check....well i logged onto the UI3, and it works locally on my BI PC........I haven't used UI3 much.......from a distance.....lemme check...yeah your right.....i tried the WAN remote address from web service and did not get thru...on my phone. But I'm not well versed on How Zerotier and UI3 would interact when attempting to logon at the Wan address, unless I need to add an additional zerotier connection....but whatever I have a pounding headache....
Good job, yes I do have banned IP's . Not sure what to do for DB. Do you continuous record ? You seem to have plenty of storage so somehow you need to reduce records.Ok, for once, I figured something out before Ken. My brother's nearly identical system was able to run 2.3 w/o any remote access issues. So I had him send me a screen shot of his advanced webserver tab. They were identical to mine, except he actually had a few banned IPs (-xxx.xxx.xxx.xxx). So I created a random wan IP and entered it as a banned IP. Immediately, all other IPs were unblocked. I forwarded this info to Ken.
But it explains why others didn't have the issue. Whether through auto-ban or manual entry, if your ip access list has any banned IPs in it, you would not have noticed this bug.
Now back to the topic of the thread (my apologies for hijacking the thread in the first place).... What is everyone doing to minimize the number of records in the DB? Mine is huge. Compacting doesn't do much.
just add -0.0.0.0 to your webserver ip access list. It's under global settings, web server, advanced. A single "banned" IP fixes the issue. Ken said the next release will fix this automatically.Yep, on 5.7.2.3, all of my tablets here were unable to connect. Went back one to 5.7.2.2 and it's all good again.
5.7.2.4 has fixed all my issues nowjust add -0.0.0.0 to your webserver ip access list. It's under global settings, web server, advanced. A single "banned" IP fixes the issue. Ken said the next release will fix this automatically.
You must have something set up causing a lot of clips like taking lots of hi res images or wrong cut and combine or something. I used to do that and was over 200,000 but blew them out and now under 10,000 with double the storage that you have.
You also have the compact/repair unchecked - are you manually doing that on a frequent basis?
Your alerts folder only needs to be 1GB unless you are storing frequent hi-rez images every few seconds LOL, but each one counts as a clip, this making your issue worse
I have over 3 times the storage of you and my clips are under 10,000, so larger drives do not equate to over 200,000 clips.
