ok, but if i've GPU, I want to use it.![]()
Use it for Deepstack or else you will have problems at some point...
Green screen on UI3 since 5.5.9.1
I changed GPU HWA on webserver, same issue with intel, nvidia or CPU
I changed profiles on webinterface, resolution, bitrate..
When I had a direct to wire version running I'd get a flash of a green screen on every 4MP camera but it always reverted to normal in under a second or so. Encoding is H264, bit rate 10240, frame and iframe at 15. That did not happen with 2MP cameras at all. The video is being processed on the CPU so it's Intel.
What was interesting is that it only happened if I used UI3 on the BI machine. It did not happen using UI3 on a networked machine like my laptop. I didn't leave that version of BI running long enough to explore what the reason might be due to problems with DeepStack conflicting with how SenseAI is incorporated with that version.
I was going to reach for the like button, but that didn't quite seem like the right sentiment. I do hope that he is taking a well deserved vacation, and this isn't due to any health issues or other serious matters. Hopefully in the meantime, lots of progress will be made on the CodeProject/SenseAI side of things that Ken will be able to integrate in when he gets back.Ken told me he won't be available for a few weeks starting today, so there probably won't be any more patches any time soon.
Roll back to a stable release.Issue "green screen" is still the same with 5.5.9.4
It was working with 5.5.9.0.
Dev team, is this issue known ? any fix ?
%017
- percentage of physical RAM in use on the systemrtsp:/user:[email protected]:81/shortname?d2w=1
