Vettester
Getting comfortable
- Feb 5, 2017
- 938
- 918
And you’re on the latest version of BI?Dark model has worked for me on CPU version since almost the beginning.
Good call. The "auto start/stop" is not starting DS unless I have facial recognition and custom models disabled.@stev067 Are you checking to make sure DS is running when you turn it on in BI? My "standard" procedure when I'm testing is to enable models, point to the models directory, stop DS, wait a minute, re-start DS and then double check to make sure it's actually running. I used that when I was running the CPU version and still do the same with the GPU version.
Well I thought I was on to something, but no matter how I do it now, I'm getting error-100's on something, whether it's just the faces portion, or everything. Inconsistent problems are the hardest to figure out.I ended up shooting myself in the foot with this, too. If it wouldn't start, I'd shut down BI, reboot, then set BI back to run as a service. That always got it all going, for me anyway.
I haven't noticed that, yet, but I will double heck later. One thing I have noticed about 5.4.9.10 is that memory management has seemed to have gotten much better. I've been tracking it for quite a while, since February, and it has normally ranged between 2 and 4.5GB over a day. Now it's been stable and under 3GB since I updated yesterday.
@hikky_b I just went back and checked all my cameras. Only two don't run sub streams because they are not capable of that, but all the others switch fine both when going full screen and during playback of clips.
