@tripp396 - what version did you update from?
I would check to see what CPU utilization is and is it close to what you had before - if not, then an issue with the upgrade.
Next make sure that in the update it didn't pull a different substream and that could be what is causing the motion differences.
And when in doubt, restart your computer and see if it clears up some junk that may have in the cache making it wonky.
