Watch:
Use zone crossing (mult zones) if you have a lot of false triggers for that camera. The video will shed a lot of light on what you're asking, but also take a look at your contrast setting of 33. Try reducing it to 25 or maybe even less...
Yes, if you go to zone B and you haven't drawn anything, then you won't see anything other than your faded zone A. That's normal.
Consider deleting that cam in BI and add a new cam, then be very lenient on the settings for the new cam...uncheck object detection and reduce min obj size and min contrast to lowest settings. Set a make time of .1 secs and uncheck black&white, cancel shadows, etc....make your camera respond to All triggers. Then you can go back and start refining your settings to discriminate triggers.
I have been able to test tree shades+ clouds + heavy winds, it results in false alerts every few minutes. Zones are not a workable solution in my case. Until BlueIris AI can distinguish tree shadows from people and vehicles, Sighthound is my main security solution for now.
Same experience here.What I tried is to just make a copy of 1 camera and enable basic on the original and edge vector on the copy. So I can easily compare the 2 methods. For now, it seems for me edge vector is still missing too many movements of people (it also reduces the false positives).
Yes, same problem here with Edge Vector enabled. With all Trigger settings the same, Edge Vector is missing people. Switched back to Simple algorithm, which is picking up some shadows but not missing people.
Perhaps you should start developing vms software so then you could decide what is important to you. No one cares about your specific use case. He knows exactly what he is doing and why.I do realize this user base has diverse use cases and needs, but for me personally, I'm kinda disappointed that v5 dev time is prioritizing and fumbling around with yet another marketable motion detection feature over basic under the hood improvements like more modern and better offloads/hardware encoding optimizations etc. Stuff like H.265 decoding and (eventually) hardware encoding using Intel QuickSync would be much appreciated for my use case!
If you were mentally balanced you would know that the blue iris developer does not read this forum. You are talking to yourself - now that is imbalanced. Why do you post here rather than email support! The world does not revolve around you and your needs. There many other vms that you should look into, hopefully they will fit your dire need for h.265 intel acceleration. Start researching.Any hard working company would love to hear feedback from a customer about wanted features. My post and the updates I see from Blue Iris itself are positive and professional discourse. It's a perfectly normal thing for mentally balanced people to do.
