- Mar 9, 2014
- 36,890
- 21,419
Yes I understand you had to turn the option off, but it was never on...you set it to on, but it never worked for h.265...its as JUST ADDED as the release notes indicates...now that it was added, the software tries to use h.265 but is not working due to a bug...it will obviously get resolved.Sorry, I had to turn off decoding as of the latest patch to get the cameras to load. They are H.265 cameras. As for the price of Intel, I haven't been able to find a used/refurbished system for less than around $600 plus. Mind you I'm looking for a I7 -7700 or above system.
You dont need an i7-7700, i7-6700 is virtually the same and can be had for 400-450. The desktop I have in my home is an elitedesk i7-6700 tower that I purchased in august 2016 (yes 2016) for 400 - total via ebay...8gb memory + 256ssd....you just need to search....
You will never be able to build an equivalent amd system for anywhere close to that unless you steal the OS and some other parts...
As the new eighth gen systems start dropping into the market these 6th and 7th gen will be even cheaper as an eighth gen i5 outperforms a seventh gen i7...
Depending on your load, you likely dont even need an i7....a 250-300 i5-6500 would do...
