2025 New Arrivals From EmpireTech
Hmmm, your 4k-x firmware is 3 years newer than mine. I'd like to try it, but your version 2.840.0000000.28R is newer than what's on Andy's web site 2.840.0000000.26. Do you remember where you got it from?
Glad to send it to ya if you want to try it, but Caveat Emptor
My other 4K-X is great on the original FW, this one has the bad nighttime noise and is oversharpened.
It wont let me revert backwards...
Well that's a damned if you do, damned if you don't choice! Keep the nicer image, or maybe detect animals while messing up the image, and if you don't like it, can't go back. My instinct is to chicken out, at least for now. I'm using both tripwire and intrusion. For the heck of it, I just turned on the object filters in the UI. Wouldn't be the first device ever that worked backwards if it turned out to work that way.
Best animal detection camera I have is a 3.6mm 4K-X with this FW and its consistent
(No it's not supposed to, but it does an incredible job of picking up critters)
The Intrusion zone is set to Humans and Vehicles, it seems to be more sensitive than the zig zag tripwire in this case
Device TypeIPC-Color4K-X-3.6MM
System VersionV2.840.0000000.28.R, Build Date: 2024-08-07
WEB VersionV3.2.1.1993215
ONVIF Version22.12(V3.1.0.1464287)
Last Night
Previously recorded
View attachment 221840 View attachment 221839 View attachment 221838
My best animal detection is with the 54ir-ze-s3 firmware 3.142.150G003.0.R
Yeah the 5442 S3's with the Animal detection filter work great.
My post was kinda tongue in cheek in that that particular camera with that FW does great on picking up critters, but it shouldn't
Failed experiment. The deer in the picture walked the entire width of the camera view with no triggers. I did get a few triggers from tall blowing grass.
I think its becasue of the top down view. I think AI modeling requires more of a side view to ID a critter, or human for that matter
Reactions: samplenhold
It's the 4k-x. The rule sensitivity was on 10, but global was on 8. I cranked it up to 10, and while I was in there turned the placebo target filter setting off again. I'm not holding out any hope of it working better. If the target filters were really off, I don't think the overhead view should make any difference.
Mebbe... the target isnt very contrast'y vs the background either
Can you crawl through the scene on all 4's to test? Even if it doesnt work it could be entertaining... :rofl:
Maybe not. But when I walk through it, it triggers. I know right away because I have the camera set to play a barking dog audio when it's triggered.
Hey guys
Radar camera will coming out soon, it will be 4G and POE optional, but we will get the poe version. Here has a draft specification for your reference.
GS-CMOS sensor!!!
this is global shutter sensor - very expensive solution, where Sony reigns supreme.
Normally, rolling image sensors used in almost all cameras, read the image line by line.
Which for very fast-moving objects causes stretching and warping.
GS-CMOS sensor is reading image full frame at once... so global shutter sensor.. no warping for high speed objects...
this ANPR cam is for highway use.. it also have some form of radar below, with speed measurement range up to 250 km/h...
I haven't get the prices, so need to check. :winktongue:
Hopefully won't be too high!
I may have to revise my guess, as it looks like you'll need to add the 4G/radar option to measure speed. So, more $$$$
