2025 New Arrivals From EmpireTech
Great Price a mini-PTZ 4MP on the ideal 1/1.8" sensor! And a Starvis sensor, so should be pretty good.
So I'm confused - are you saying that since the SD5R404GA has a Starvis sensor, it should have better low-light capability than the PRO and 5442-S3 ... because it has a better technology sensor?
If I try to compare using Dahua's spec's (ideally should be with similar conditions), it says for Color:
0.001 @ F1.0 - SD5R404GA
0.0003 @ F1.2- HDW5459H-ZE-PV-PRO
Should be about equal to the 5442 S3
Weird I can't find it on Dahua's website?
OK found it
OK found it
Andy @EMPIRETECANDY
How are the white LED's activated? I don't see any reference to "Smart Illumination"?
Can they be activated by IVS?
Can someone get a sample and MAKE some testing?
